Old 07-14-2020, 10:22 AM   #1
1le.matt
1le.matt's Avatar
Drives: 19" 1LE 2.0T
1LE 2.0T Lowering Springs?????
Hey everyone, I feel like im pretty good at searching but couldn't find anything on this. Apologies if this has been covered already, but does anyone know if any company makes a set of lowering springs for the 1le 2.0t? the closest i could get was a member here that used a set of AFE springs on their 2018 v6 1le and it worked as advertised. Also the springs say for v6 and i4 but no mention of 1le variants. at this point you might say well no brainer, actually even as i write this it makes a little sense, but my confusion comes in that mine is a 2019, first year for the 2.0 1le, and when i called AFE they couldn't confirm because the springs are only rated to the 2018 model year.
Hope this makes sense!
Thanks!
1le.matt is offline   Reply With Quote
Old 07-14-2020, 01:48 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I believe the v6 and 2.0t use the same springs, anything 2016+ will work since no changes were made to the suspension
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Old 07-21-2020, 11:34 AM   #3
1le.matt
1le.matt's Avatar
Thanks! Thinking i'll pull the trigger on the AFE ones.
Old 07-21-2020, 11:43 AM   #4
foshjowler
foshjowler's Avatar
Drives: 2017 Camaro 2.0T, 91 Miata
Further more, I believe I saw somewhere that the front springs on the 1LE are the same as the non-1LEs
305 BFG Rivals FTW
Youtube Channel
foshjowler is offline   Reply With Quote
Old 10-21-2020, 09:46 AM   #5
1le.matt
1le.matt's Avatar
Thanks guys! Just swapped in the AFE springs. Went together with no problems and no problems with alignment.
