Old 07-09-2020, 11:32 PM   #1
Wipeyourself
Wipeyourself's Avatar
Drives: 2019 2LT RS V6 A8
A845 tranny codes.
Two tranny codes today on route to work. I did erase them. Check engine light is off. Car drives fine so I guess its a wait and see situation for now. Just documenting this for the forum. I will update anything that comes up. Its a 2019 8l45.
Wipeyourself is offline   Reply With Quote
Old 07-11-2020, 02:27 AM   #2
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
I had a transmission temperature sensor short back in March. I didn’t get the code because I don’t have a scan tool atm.
Had to get a lot of work done.
ItsChristianInHD is offline   Reply With Quote
Old 07-11-2020, 12:08 PM   #3
Wipeyourself
I read somewhere (probably on here from u) that the valve body has to be removed to access the part. Car seems flawless currently so if the codes come back i will have gm advise me on the situation.
How long did the dealer have your car ?
Old 07-14-2020, 10:07 PM   #4
SirPhobos1
STAY PUFT
Drives: Gone
My transmission did the same thing last winter. It started with these codes, with normal performance and eventually turned into a scenario where I couldn't drive more than 10-15mph, stuck in first gear.
Dealer replaced valve body and the harness that caused the original CEL.
So far, so good. Covered under powertrain warranty.
2016 Hyper Blue Metallic 2LT RS - 6/13/2018-4/5/2022
SECOND 2010 Synergy Green Metallic - 5/4/2012-4/15/2016
2010 Synergy Green Metallic - 4/21/2010-7/15/2011
SirPhobos1 is offline   Reply With Quote
Old 07-15-2020, 07:24 AM   #5
ItsChristianInHD
My car was at the dealership for a week I’d say
