03-05-2020, 10:14 AM | #71 |
Drives: 2019 Camaro RBM M6 LTG 1LS Join Date: May 2018
Need that anti-lag technology that can be engaged for autocross and cut off on the way home. Throttle delay is a big issue on the 4T. It really showed up Sunday on a narrow airport runway, both turn around radius's where you are out of the gas for an extended amount of time and then opening up to a straight. Tried to give a little gas to start building boost and of course I just pushed the front end then. Zmax course layout suits our cars so much better.
Is left foot brake the way not sure I'm up for that. |
03-05-2020, 10:24 AM | #72 | |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
03-06-2020, 10:40 AM | #73 |
Josh, I will be watching and learning as you prep your car for a CAM-C autocross build. It's going to be fun watching you compete against the V8 pony cars. This past holiday season sale I was very, very close to buying some Apex 19x10.5 wheels. But in the end I just decided to stay put for one more season.
03-06-2020, 12:25 PM | #74 | |
Drives: C5 Z06 Join Date: Mar 2016
With only 5MM clearance sounds like you don't have room for the old slotted strut trick anyways. I'm sure you know this but you will really save on tire wear when you get buy camber plates. 550$ for camber plates VS 1200$ for tires Camber plates payoff quickly. |
03-10-2020, 10:14 AM | #75 | |
Drives: Pending Join Date: Oct 2018
I wouldn't put much faith in that being a real fix without more research or probably trying it myself. But we can hope. If 4T turbo lag can't be readily fixed, perhaps a V6 would be a better starting point for a nose-light CAM-C effort. |
03-10-2020, 10:36 AM | #76 | |
I prefer the 4T because turbo motors are easier to upgrade, and it doesn't sound like the V6 has much aftermarket support. |
07-04-2020, 12:38 PM | #77 |
Drives: Boost Coupe Stewie formerly '01 Z28 Join Date: Jan 2007
Hi all,
We're starting to think about our next autocrossing car after almost a decade of Corvette humbling in AS & SSR. Up for consideration is joining DS in a Turbo 4. The deals are too good to pass up for something new. With that said, what are the thoughts on the Turbo 4 in DS? I'll have some class competition locally/divisionally with Bruce Bellom and his 1LE DS Camaro as well as a few other folks, so hopefully some of the "fun" returns. It is an uphill battle with the Hype-R? Has the time window of the T4 come and gone? Any input is appreciated (maybe other than "Thank you for your input" :P ). |
07-05-2020, 04:36 PM | #78 | |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
07-06-2020, 07:34 AM | #79 |
Interesting points. Certainly we would want to run the car Nationally. Heck, locally around here in the Northeast can be like going to big events with the talent pool. At best, we can at least get ourselves to the first page of results but not quite the pointy end. I'm not sure if our talent level could surmount that uphill battle though.
