06-07-2019, 04:57 PM | #1 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Pcm terminal
Does anyone know what kind of terminal the pcm uses. The same one as the flex fuel kits use that plug in down there.
I'm trying to make a custom little deal to get tach signal without cutting the factory wires. I have tried emailing several makers of the flex fuel kits to no avail. Either stop responding or the don't know what one it is... Any help would be appreciated!
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance Last edited by Dubchitts; 06-08-2019 at 01:39 AM. |
Thread Tools | |
