Old 12-18-2017, 02:50 PM   #15
Web9
Web9's Avatar
Drives: 2018 Camaro ZL1 1LE
Originally Posted by Glen e View Post
Some track guy will come along here and say “I wouldn’t do that at all”… So you have to make your own decision…
If you’re worried, you could do some with bolts/Nylock s and some with push poppers, I’ve been 100 miles an hour in mine but not to the track. I just used 3/8 inch push pops from Lowe’s ...just go over to Lowe’s and look at the options available...
I'll check it out. Should be able to tell pretty quick if they will hold sturdy enough.
Web9 is offline   Reply With Quote
Old 12-18-2017, 03:22 PM   #16
nasbagoat
Drives: 17 SW 1LE
My 15 wrx had the coolest attachment method for the front splitter, they use these flanged rubber barrel nuts. You drilled the hole, pushed the nut in up to the flange, put the spoiler in place and bolt it up. As you tighten the screw it balloons out the sides of the rubber barrel, creating a almost rivet like effect but it was reusable.
nasbagoat is offline   Reply With Quote
Old 12-18-2017, 04:45 PM   #17
Web9
Web9's Avatar
Do you mean expansion nuts (below)? If so, that would also work, but the holes might need to be drilled larger. Good option though
Old 12-18-2017, 07:30 PM   #18
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
does a clearbra proteaction on the splitter offer any added protection?
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 12-18-2017, 09:09 PM   #19
MAGAUSA
MAGAUSA's Avatar
Drives: 2017 Hyper Blue 1LE
Not for that kind of damage. That is the same as when I ran into a concrete parking barrier.
MAGAUSA is offline   Reply With Quote
Old 12-19-2017, 07:30 AM   #20
nasbagoat
Drives: 17 SW 1LE
EXACTLY!!!!
Old 12-19-2017, 10:57 AM   #21
Teneck83
Drives: 2018 SS 1LE
Cracked my splitter leaving the dealership immediately after purchased. Tire retread on the Jersey turnpike
2018 ZL1 1LE
1966 Corvette 427/425 vert
1969 Corvette 350/350
Teneck83 is offline   Reply With Quote
Old 12-19-2017, 11:16 AM   #22
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
For track use, run a strip of Gorilla tape across the leading edge.
JusticePete is offline   Reply With Quote
Old 12-20-2017, 02:31 PM   #23
antd51
Drives: 2017 Camaro SS 1LE
Yes i have had the same exact problem i would assume that came from a rock , most likely had my music blasting and did not hear the impact.
antd51 is offline   Reply With Quote
Old 12-29-2017, 09:59 AM   #24
SaphfireSS
Drives: 2017 Camaro 1LE SS
They don't like autox cones either. Lol
SaphfireSS is offline   Reply With Quote
Old 12-29-2017, 10:04 AM   #25
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
jsut damaged mine as well :( ... time for a new one .. i don't think i'll go OEM...
anyone have this one ? seems really good for C/F? price point wise..
https://www.ebay.com/itm/T6-Style-Ca...53.m1438.l2649
cmeJATT is offline   Reply With Quote
Old 01-01-2018, 11:54 AM   #26
toehead93
Drives: 2014 2SS/1LE
That’s crazy. My 2014 has taken lots of abuse and has few dents but no cracks.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 02-06-2018, 08:06 AM   #27
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
What is the part number for the OEM SS 1LE satin black spoiler?
Old 02-06-2018, 09:05 AM   #28
nasbagoat
Drives: 17 SW 1LE
84116158
