01-07-2017, 01:59 PM | #1 |
Left Lane Enforcer
Drives: '18 ZL1 1LE. Join Date: Jul 2016
Loudest Camshaft for SS
I want the camshaft with the loudest idling sound and if you believe there's a camshaft that's overall better than the loudest camshaft suggest that as well.
Thanks!
Current Cars:
2018 Camaro ZL1 1LE 2012 Ford Focus SE 1994 Evo II Previous Cars: 2017 Camaro SS 2014 Chevy Malibu LTZ |
01-07-2017, 02:08 PM | #2 |
SABIO
Just run 3" straight pipe. Cost you $200.
Save yourself $4000
01-07-2017, 02:17 PM | #3 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
That'll do it. Or an MBRP Race.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
01-07-2017, 03:40 PM | #4 |
Drives: 2016 2SS Join Date: Jul 2016
Maybe he meant lopiest?
For lope, overlap is your friend. Large separation in intake to exhaust duration and a tight lobe separation. I don't have enough experience with these motors to give any actual specs. You will need a converter if you are A8. Compression has some to do with the cam sound but your exhaust it the biggest determiner of actual volume.
01-08-2017, 10:45 AM | #5 |
Drives: SS 6 speed of course Join Date: Jan 2016
since we are not talking about HP or performance ect, the biggest cam for cheap would be a comp cam say 224 / 236 on a 116 keep the stock rev limiter and it will SOUND bad action... with no other parts to back it up expect: huge loss of power in the midrange.. low end part throttle will be terrible. 423-13 is the part number for you.
01-08-2017, 11:05 AM | #6 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
Here is my car with cam running wide open, if you want loud just get the cutouts, i can not drive on highway with cutouts open, everything in the car vibrates from the sound.
https://youtu.be/zQ81gm3MRqk
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
01-08-2017, 11:15 AM | #7 | |
01-08-2017, 11:43 AM | #8 |
Thanks Oldman lol, but at 143 in that video i closed the valves to tour mode and you can gear the obvious difference in sound. Something I noticed is that with the cutouts open you cannot hear the cam chopping, with it closed and running through mufflers you can hear the chop.
In car video https://youtu.be/j2OSzedNrWc
1ss/Auto-Hyper Blue
01-08-2017, 01:13 PM | #9 | |
Drives: 2016 Chevy Camaro Join Date: Jun 2016
01-08-2017, 01:23 PM | #10 | |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
Sent from my SM-G920V using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
01-08-2017, 02:13 PM | #11 |
SABIO
Sigh. Wish I could just figure out just a Cam...smallish is fine. I am more into the Sound.
Don't need the upper rpm. BTR makes one. Is this small? 22? In / .22? Ex @.50. .60x .60x. 114+6 (is the +6 ICL) Part# is 2242328146.... almost like the real duration is the part# ??
01-08-2017, 03:35 PM | #12 |
all parts of post, I thought that only happens with the Oldlady: cheap, chop, rpm limit with stock springs or the loss of mid range power and poor part throttle tip in... LOL Comp itself list the cam as losing power in the midrange. I merely speculate that a 292 duration cam on a small block is going to have poor part throttle tip in.... same duration I run on my bored and stroked 440 BTW... I will say "poor" is relative, would you be OK as not as good as the phenomenal stock drive-ability? Still better than a stock LS3... probably... better then a 5.0 yep.
01-09-2017, 07:00 PM | #13 |
Drives: 2019 Mustang GT Convertible Join Date: Oct 2016
Gear Drive
[QUOTE=gosutag;9492705]I want the camshaft with the loudest idling sound and if you believe there's a camshaft that's overall better than the loudest camshaft suggest that as well.
Don't forget the gear drive timing chain replacement; that sounds bad ass too. |
06-11-2019, 07:44 PM | #14 |
Drives: SS-6-SPD Join Date: Jan 2017
I’m looking for opposite ...
I’m about to cam my cause but want to switch to exhaust which can tone down the volume in tour mode .. What would be better Stainless Works or Borla SType ? |
