![]() Drives: 2020 1lt Join Date: Apr 2021
engine cover removal
I searched the forum but no luck. I took the engine cover off to be able to see the engine better. There is a insulation material on the intake that looks bad . Can it be removed and what is the best way?
Long hauler
If you're talking about the material underneath the intake manifold then you can take that off without errors. I believe it's just there for sound dampening, the v8 guys take it off usually when changing intake manifolds
2016 1LT v6 - Totaled Happiness: Infinite |
Under the plastic engine cover
![]() Drives: 21 Camaro RS manual v6.Tyota Tacoma Join Date: Feb 2021
I think engine cover is just for noise suppression.Any body run without it?
![]() Drives: 2017 1LT Camaro Join Date: Jun 2019
I've replaced all six spark plugs since owning my 2017 6th gen. I tore away small sections of the material just so I could reach the spark plugs. I'm almost certain it won't hurt.
My son is trying to convince me that it is insulating the intake manifold from engine heat.
#7 | |
Long hauler
All you're getting really is just more noise, no issues should come up as long as you put the bolts back on properly and not loose.
