11-24-2017, 01:07 AM | #15 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
Properly designed and installed bolt ins can be every bit as safe as a weld in. Weld ins can also puncture a floor.
That being said, either one is a death sentence in a street car driven without a helmet. |
11-24-2017, 01:17 AM | #16 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
11-24-2017, 09:11 AM | #17 |
Drives: 2018 camaro zl1 , 2007 porsche GT3, Join Date: Dec 2016
11-27-2017, 09:44 PM | #18 |
Drives: Duramax Join Date: May 2017
11-27-2017, 10:35 PM | #19 |
Thank you! Correct! I’d go a step further and say head restraint seat or device too. Someone was killed at Buttonwillow a couple years back in a caged race car after sliding into a flag tower pitched 90* sideways. VERY experienced driver too. Caged car. Racing seat. But that side impact is not neck friendly.
I have the RaceTech..... I think it’s the 4119. LOVVVVVEEEE IT. And feel very safe in it. |
11-30-2017, 12:30 PM | #20 |
Drives: 2015 Z06, 2017 1LE (possibly) Join Date: Apr 2017
I've got an RPM bolt in rollbar. Foot pads and sandwich plates are well designed but I agree about punch-thru risk especially where they bolt into the wheel wells. The floor mounting point it utilizes seems pretty robust, wheel well, not so much.
2017 Red Hot 1LE - Corsa Xtreme Exhaust - Borla Mid Pipe - K&N Intake -Stock Otherwise! For now...
11-30-2017, 06:47 PM | #21 |
I just ordered a RPM rollbar too. Hopefully none of our concerns ever come into play..
01-01-2018, 02:43 PM | #22 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Would the RPM be practical to install/remove as needed on a Vert for HPDE events?
01-01-2018, 04:42 PM | #23 |
01-01-2018, 05:03 PM | #24 |
Right. Have you completed your install? What would you expect the time frame to be on the Vert verses the coup? I honestly have not researched the removal process yet.
01-01-2018, 05:20 PM | #25 |
I havnt recieved mine yet. It's supposed to ship this week. From what i understand it should take a couple hours to install.
01-01-2018, 05:40 PM | #26 |
Drives: ZL1 1LE Join Date: Oct 2016
Are you going to try to mount a 5 or 6 point harness with the stock seat?
Now with the ZL1, I like the idea of a roll bar more and more. Though I wouldn't personally do it unless I could use a 5/6pt. harness in addition to a fixed back seat. My concern then has to do with the airbag system and tricking the car into believing the system is good to go despite the removal of the seat. Without all these, I have to wonder if the car would actually be less safe than if I had just left everything stock. Thoughts? I also kind of like the idea of having a/c and heated seats in my track monster
01-01-2018, 05:56 PM | #27 | |
Here is the seat that I've gone with. It has removable halo sections, in case i want to drive on the street too. |
01-01-2018, 06:53 PM | #28 |
That's a good idea. What seat mounts are you going with? Just going to handle the Airbag warning light all the time? I wonder if a simple resistor could mitigate the problem.
