03-21-2016, 09:26 AM | #1 |
Drives: black and silver Join Date: Apr 2014
wet sanding
hey guys looking to get the car wet sanded. i went to the shop that did the custom paint on my car the price he gave me was 8 hunderd dollars for the whole car... that seems way to much for a wet sand.. can you tell me if this sounds right to you or i should look somewhere else thanks
03-21-2016, 11:57 AM | #2 |
Drives: 2010 1SS Camaro Join Date: Jun 2015
I'll tell you what, you try wet sanding an entire car. It's a lot of work for quality and going to take a lot of sand paper to get the orange peel out, not burn through the clear, and then polish it all out. I'd gladly pay $800 if it came out without any burnt spots. It's a skill and an art.
Got to tape all the trim, glass, etc. anything you don't want compound on. |
03-21-2016, 11:59 AM | #3 |
so 800 is a good price then.. some other shop just told me 250
03-21-2016, 12:01 PM | #4 | |
03-21-2016, 12:29 PM | #5 |
Any time... If they painted the car, they know how much they can take off. If anything happens they'll be able to fix it.
03-21-2016, 04:56 PM | #6 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
I would also assume it depends on how fine a grit they wet sand down to.
Do the stop at 320 grit, 500 grit, 1000 grit, 1500 grit or finer yet, etc. Does the $800 include the final polishing/buffing stages? I would assume it does? |
03-21-2016, 05:10 PM | #7 |
Canadian
Drives: 2011 Camaro 2SS/RS Join Date: Dec 2013
to do a proper wet sand you start at 800 >1000>1500>2000>3000 than 3 stage buff compound>scratch remover> swirl remover...... ask me how, I know just did the wet sanding this weekend for a friend, do the polishing/buffing this weekend
2011 Camaro SS/RS
--------------------------------------------------------- The cars we drive say a lot about us. |
03-21-2016, 05:55 PM | #8 | |
It's just when two people use the term 'wet sanding' and one charges $250 and the other charges $800, it makes me wonder just what they each mean by the simple term 'wet sanding'. Sorta like comparing a Earl Schieb $29.95 'paint job' to a professional 'paint job' It's just a good thing to be sure you understand just what you get in each case. |
03-21-2016, 11:52 PM | #9 |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
You better measure the paint thickness before you consider wet sanding. Clear is very thin on these cars.
03-22-2016, 11:39 PM | #10 |
Drives: 2013 Camaro 2LS Join Date: Feb 2013
03-23-2016, 10:48 AM | #11 | |
03-23-2016, 12:24 PM | #12 |
Drives: 2014 SS Join Date: Aug 2014
what does wet sanding do to your cars surface
03-23-2016, 01:08 PM | #13 |
Canadian
when you look at any factory car the paint isn't truly crystal clear, it has what is called orange peel in the clear, what is that you may ask, it highs and lows in the clear and causes what looks like an orange peel when looking at your paint.
What does wet sanding do? It removes little bits of clear to level out your paint. starting with the most aggressive grit at 800 which will take the most clear, than the next grit at 1000 will pull out the scratches that the 800 leaves as well as a little bit more clear and so on and so forth with the 2000 and 3000. you will notice after decreasing the grit on the paper the paint will gain some shine back as you go higher in number. what buffing and polishing does, is remove the very fine sanding marks to give you a crystal clear finish to the clear. see photo below. it is not my photo just one I found on google.
2011 Camaro SS/RS
03-23-2016, 08:01 PM | #14 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Kind of off topic, but I just had paint work done, can I use my pc7424xp and Adams fine machine polish to get out some light scuffs I noticed? Been painted since Saturday, I won't be sealing or waxing for a month
UPSTATE C5 MEMBER
Thread Tools | |
