04-30-2015, 09:57 AM | #1 |
BFGoodrich g-Force COMP-2 A/S
Wow! Have any of you seen these yet? Looks like they will be coming out with sizes that fit the factory ZL1 wheels in the August - September timeframe.
- Front: 285/35ZR20 - Per Tire:$171.00 - Rear: 305/35ZR20 - Per Tire: $181.00 - $704.00 plus shipping from Tire Rack http://www.bfgoodrichtires.com/tire-...s/tire-details
2015 Camaro ZL1 (#1090)
04-30-2015, 11:04 AM | #2 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
The summer version of that tire isn't very good, so I probably wouldn't put too much stock in the All season version either.
The summer version is super loud on the street and feathers very badly if you do a lot of cornering.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
04-30-2015, 12:35 PM | #3 |
I have had no issue with the summer version of these tires. They make less noise and ride smoother than my old Pirellis did. They run slightly wider than stock Pirellis though so the grooves in the street pull my car around a lot more now.
04-30-2015, 02:01 PM | #4 |
The gritos pollo!!!
No complaints with my summer comp-2, I will never run a another all season though. Right tire for the right situation. "Jack of all trades, good at none"
______
If you don't stop how can they give you a ticket?-The Big Tuna___ '12 1Ls Camaro; Slp loud mouth I|maganflow x-pipe|Injen long ram intake|brembo brake upgrade| russell s.s. lines|2LT polished 19's|billet 5mm spacers|tinted tail lights&markers|pdmi|billet c. can| '13 Avenger R/T '77 T/A 6.6;, draining my wallet. |
04-30-2015, 02:36 PM | #5 |
Drives: 1-800-428-8355 X4664 Join Date: Sep 2010
Don't count out this new tire. We will test it soon. It should prove to be very competitive and the price on these are very good.
04-30-2015, 02:43 PM | #6 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
I want to see a test! I had a set of the Comp-2 on the old Camaro, they were very nice.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
04-30-2015, 09:15 PM | #7 |
At $704 plus shipping...I can guarantee I will at least try them out when I need new tires.
05-01-2015, 10:52 PM | #8 |
Drives: 69 Camaro & 2013 Camaro 2SS/RS/1LE Join Date: Jun 2013
I need tires to. Many on back order.
2013 IO 2SS/RS 1LE (1 of 95)
05-01-2015, 10:57 PM | #9 |
Drives: 2015 Redhot 1LE Join Date: Feb 2013
I never understood that...seems every time I check for some specific tire I need they are always on backorder you would think the manufacturers would actually produce enough to meet the demand. I guess they are not in the business of making money.
05-02-2015, 12:11 AM | #10 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
I love my Comp-2s.... No problems and I drive hard
2011 2SS/RS built 8/24/10
05-02-2015, 04:14 AM | #11 |
The gritos pollo!!!
What's your life span on them
______
05-02-2015, 02:45 PM | #12 |
Drives: Firebird 95, Equinox 05, Camaro 2SS Join Date: Aug 2009
Great tires, although not for the CAMARO Gen 5
@ I have just installed the summer version of these tires on my '95 FIREBIRD.
Is the third time time in a row that I installed G-Force Ultra High Perfomance tires in that car over the several years I have owned it. These are the first set with the COMP-2 rubber formula as it became available recently. If you care to have a look at My ALBUMS or My GARAGE here in this forum you will find a listing of all the mods made to this vehicle. Not too shabby; I think; I mostly like the cornering abilities of it as you can see from all the suspension/stability , mods I made. These tires are fantastic for the FIREBIRD but I will never place them in my CAMARO. In fact right now I'm searching for tires and becoming a bit desperate as I have not been able to find top "Max Performance Summer" tires in the past 60 days. Even so, I will not buy a set of these for the CAMARO as I think they will not handle well the 420 lb/ft of torque the engine churns out. As another member already pointed out, the corners of this tire tend to wear rather fast and I strongly suspect the higher torque of the CAMARO will destroy them even faster. Also the initial bite in standing starts will get eaten fast by the powerful LS3 so I will recommend you search a bit more, unless you really drive at a relaxed pace with just an occasional burst of power lunches few and far in between. That's my two cents. Great tire but not for this application I believe. Safe driving!! The Flash
05-02-2015, 05:16 PM | #13 | |
DITTO!
Sir, you took the words right out of my mouth!!
