Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 05-03-2011, 10:52 PM   #1
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
A Look at GM's Oil Life Monitoring System
I read this post on another forum at www.bobistheoilguy.com
Good read on the "Big Bird" break down of the oil life monitoring system.
One thing I can touch on and clear up.....the GM oil life monitor operation and my statement that ZDP (or ZDDP as you tend to call it here...most of the API literature just sticks to ZDP so I tend to use that) depletion is the basis for oil deterioration.
My spelling is poor but ZDP stands for zinc dialkyldithiophosphate which , as it sounds, is an anti-wear compound comprised of zinc and phosphorus.
ZDP is dispersed in the oil so as to be at a potential wear site if a surface asperity happens to break thru the oil film thickness causing the dreaded metal-to-metal contact. A molecule of ZDP must be present at that moment to prevent microwelding at the contact site which will cause material transfer, scuffing, scoring, wear and catostrophic failure. The concentration of ZDP in the oil will determine if there is ZDP present to work it's magic. The greater the concentration...the more likely a molecule of ZDP will be there...and vice versa.
By nature, ZDP is sacrifical. As ZDP is "used up" at a wear site to prevent micorwelding the concentration of ZDP decreases.... So...if you measure the ZDP concentration in engine oil in a running engine it will decrease at linear rate based on engine revolutions. Any given engine has a certain number of high potential wear areas where metal-to-metal contact could occur due to reduced film thickness and/or surface asperities....areas such as rubbing element cam followers, distributor gears, rocker arm pivots, push rod tips, etc...... The more of these areas the more ZDP depletion. The more often these features come in contact the greater the ZDP depletion. That is why, generally speaking, ZDP concentration in the oil, for any given engine, will decrease at a fairly linear rate when plotted versus cummulative engine revolutions. The more times it turns the more contact the more chance for wear the greater the depletion. This is as much of a fact as I could quote ever and is really not speculation or anything. It is proven beyond a shadow of a doubt in many studies. That is why it is ONE of the basis for determining oil life remaining and why it is THE basic premis of the GM oil life algorithm. It is only ONE of the things that determines oil life...but it is the one thing that can be tied to engine operation in a linear fashion and estimated very accurately by accumulating engine revolutions via a counter.
The GM engine oil life monitor counts engine revolutions and accumulates the number for the basis of the oil life calculation. It then adds deterioration factors for operating temperature, start up temperature, soak times, ambient, coolant temperature, etc... There are a LOT of factors that "adjust" or affect the slope of the deterioration but the fundamental deterioration is traced back to the ZDP depletion that is inescapable with engine revolutions. The specific rate of ZDP depletion is readily measurable for any given engine so that is the fundamental item that is first calibrated for the oil life algorithm to tailor it specifically to that engine.
You would obviously like to get the oil out of the engine before the ZDP concentration gets so low that it is ineffective at being at the right place at the right time and preventing engine wear so that becomes the long term limit on oil life for that application.
The other things that determine oil life such a acid build up, oxidation, petane insuluables such as silicon from dust/dirt, carbon or soot build up from the EGR in blowby, water contamination, fuel contamination, etc.... are all modeled by the multipliers or deterioration factors that "adjust" the immediate slope of the line defined by the engine revolution counter as those items can be modeled in other ways and accounted for in the immediate slope of the ZDP depletion line.
The algorithm was developed over the course of many years by several lubrication experts at GM Fuels and Lubes, spearheaded by Doctor Shirley Schwartz who holds the patents (with GM) for the algorithm and the oil life montitor. I had the luck of working directly with Dr. Schwartz when the idea of the oil life monitor first progressed from the theoretical/lab stage to real world testing/development/validation. There were fleets of cars operated under all conditions that deteriorate the oil life for any and every reason and , thru oil sampling and detailed analysis of the oil condition, the algorithm was developed, fine tuned and validated to be the most accurate way invented yet to recommend an oil change interval by. As just one example, I have seen cars driven side-by-side on trips, one towing a trailer and one not, for instance, to prove the effectiveness of the oil life monitor in deteriorating the oil at a faster rate just because of the higher load, higher average RPM, higher temps, etc...and it works flawlessly.
The oil life monitor is so effective because: it is customized for that specific vehicle/engine, it takes everything into account that deteriorates the oil, it is ALWAYS working so as to take into account THAT INDIVIDUALS driving schedule, and it tailors the oil change to that schedule and predicts, on an ongoing basis, the oil life remaining so that that specific individual can plan an oil change accordingly. No other system can do this that effectively.
One thing is that I know personally from years of testing and thousands of oil analysis that the oil life algorithm works. There is simply no argument to the contrary. If you don't believe me, fine, but, trust me, it works. It is accurate because it has been calibrated for each specific engine it is installed on and there is considerable testing and validation of the oil life monitor on that specific application. NOt something that oil companies or Amsoil do. They generalize....the oil life monitor is very specific for that application.
Oil condition sensors in some BMW and Mercedes products are useful, also. They have their limitations, though, as they can be blind to some contaminates and can, themselves, be contaminated by certain markers or constituents of certain engine oils. Oil condition sensors can only react to the specific oil at that moment and they add complexity, cost and another potential item to fail. One other beauty of the GM oil life monitor is that it is all software and does not add any mechanical complexity, mass, wiring or potential failure mechanism.
There is considerable safety factor in the GM oil life monitor. Typically, I would say, there is a 2:1 safety factor in the slope of the ZDP depletion curve....in other words, zero percent oil life per the ZDP depletion is not zero ZDP but twice the concentration of ZDP considered critical for THAT engine to operate under all conditions reliably with no wear. This is always a subject of discussion as to just how low do you want the ZDP to get before the oil is "worn out" if this is the deciding factor for oil life. We would tend to be on the conservative side. If the oil life is counting down on a slope that would recommend a 10K change interval then there is probably 20K oil life before the ZDP is catostrophically depleted....not that you would want to go there...but reason why many people are successful in running those change intervals.
Please...NOT ALL ENGINES ARE THE SAME. The example above is an excellent practical justification of why you would want to add EOS and change the 15W40 Delvac in the muscle car at 3000 miles max and yet can run the Northstar to 12500 easily on conventional oil. You must treat each engine and situation differently and what applies to one does not retroactively apply to others. This is where Amsoil falls short in my book by proposing long change intervals in most everything if you use their oil. It just doesn't work that way. You can run the Amsoil to 12500 with no concerns whatsoever in the late model Northstar because even the oil life monitor tells you that for conventional oil off the shelf. Would I do that to the 502 in my 66 Chevelle...NO WAY. Amsoil says I can though. Wrong.
There are entire SAE papers written on the GM oil life monitor and one could write a book on it so it is hard to touch on all aspects of it in a single post. Hopefully we hit the high spots. Realize that a GREAT deal of time, work and energy went into developing the oil life monitor and it has received acclaim from engineering organizations, petroleum organizations, environmental groups all across the board. It is not some widget invented in a week and tacked onto the car.
franknbeans is offline   Reply With Quote
Old 05-03-2011, 11:06 PM   #2
pogiskier
pogiskier's Avatar
Drives: 2011 camaro 2ss black,hurst shifter
This cool I would like to learn more.
pogiskier is offline   Reply With Quote
Old 05-03-2011, 11:17 PM   #3
coolman
Guest
So I guess me waiting until I get the warning is the right thing to do. I always say, Why waste the oil when there's nothing wrong with it. I usually get about 6 to 7 thousand miles on my trucks before I need to change according to the monitor. That saves a lot of money and down time when you have a fleet over taking them in every 3,000 miles weather they need it or not.
coolman is offline   Reply With Quote
Old 05-04-2011, 12:08 AM   #4
TOMS1SS
Drives: NA
Let's just hope that 3,000 miles or less BS has been put to rest for good.
TOMS1SS is offline   Reply With Quote
Old 05-04-2011, 12:10 AM   #5
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
Just changed mine with 10% left.
Seems like the right time to do it.
Old 05-04-2011, 12:14 AM   #6
TOMS1SS
Drives: NA
Just changed my oil in both my cars:
Camaro: 7,200 miles with 28% left after one year. The manual says to wait for the DIC or one year.
Fiesta: 10,076 miles when the oil change sensor went off. The Ford manual states to change the oil every 10,000 miles.
- For the record many car companies go a lot further than even 10,000 miles. Oil is SOOOOO much better than was when 10W40 and 3,000 miles were the standard.
Old 05-04-2011, 12:22 AM   #7
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
yea I am waiting to it goes to about 10% before I take it in... synthatic last longer and protects better then reg oil.. I must admit, did not think it was that involved, just thought it went by GM and the Mileage since the last oil change...
MARINE1991 is offline   Reply With Quote
Old 05-04-2011, 12:31 AM   #8
lawman007
Panama-Gulf War Vet
lawman007's Avatar
Drives: '11 SW 1LT/RS 6M
I like it when research vilifies my laziness...lol!!! That was good that GM did provide the research in developing this feature.
Troy Lawson
lawman007 is offline   Reply With Quote
Old 05-04-2011, 12:36 AM   #9
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
very helpful, thanks for the post. I change mine at 30% oil life yet, not neccessary but theres piece of mind for me, as going lower does not harm the engine. However, is there a TSB or something on GM reseting the oil life monitors on our Camaros? I swear I heard something like that, not sure if it was a rumor or not. None the less great thread!
CAMARO
Consult your doctor before taking Camaro
Side effects include Sudden increase in Heart Rate, Insomnia and occasional hallucinations
If you experience Permagrin exceeding 4 hours after taking Camaro, seek immediate Camaro5 Help
CAMARO Bringing excitment back into the Garage
TJ91 is offline   Reply With Quote
Old 05-04-2011, 01:19 AM   #10
Lumix
Lumix's Avatar
Drives: 2015 1LT
I heard the same thing. Don't have a clue if it's true or not. Wish there was a reliable way to find out.
Lumix is offline   Reply With Quote
Old 05-04-2011, 05:29 AM   #11
Number 3
Hail to the King baby!
Number 3's Avatar
I've posted often that there is a ton of science behind the OLM on GM vehicles. There is still a lot of skepticism based on the "old school" and personal history.
I still go to get the oil changed in Mrs. Number 3's Malibu. She has 100 mile highway commute and the OLM will easily go to 10,000 miles. I always get the, "ohhhhhhhh, you shouldn't wait so long to get the oil changed, it's verrrrrry dirty". So someone less technical or without the belief in the science might be scared back into the 3,000 mile change.
GM never really got the credit for this, but their point was to be greener by changing your oil as needed, not at 3,000 miles "just because".
Number 3 is online now   Reply With Quote
Old 05-04-2011, 06:05 AM   #12
Mark H
Drives: 04 Denali
Originally Posted by Number 3 View Post
I always get the, "ohhhhhhhh, you shouldn't wait so long to get the oil changed, it's verrrrrry dirty". So someone less technical or without the belief in the science might be scared back into the 3,000 mile change..
Do you ever tell them who you are and where you work?
Could be pretty funny.
Mark
But Officer, I swear its just a vacuum leak.
Those red things? those are smog pumps!
2004 Sierra Denali ----- 2/4 drop
LSX 438 TWIN TURBO
LSX Block Video
Block number 00370. Build Date 04/17/2007
Mark H is offline   Reply With Quote
Old 05-04-2011, 06:22 AM   #13
kennyo
kennyo's Avatar
Drives: 2017 2SS Hyper Blue
Very informative.That's what I looked at it as-a widget.Definitely gonna wait til 10% now.
kennyo is offline   Reply With Quote
Old 05-04-2011, 06:27 AM   #14
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '20 Corvette Stingray
There IS something, but it has to do with the same V6's in Caddy's (same engine in our Camaros). I have one, and I got the notice in the mail about a month ago. It was labled as a RECALL but all it said was, and I ask my service manager about the specifics, they (GM/CADDY) recalibrated the system, no parts were changed. The deal is, in the Caddy's, there have been reported timing chain failures and/or advanced wear based on the oil change frequencies based on the monitor system alone. SOOOO it was time for me to get the oil changed anyway, had the dealer do the oil/filter change and do the update to the monitoring system while they were at it.
Seeing as how I have typically done all my oil changes at the 50% mark, which was normally at or about the 10000 mile mark or aq little more.....I figure I was more than safe.
AFM turned off by my dealer???? fastfreddie 5th Gen Camaro SS LS LT General Discussions 95 08-25-2012 02:55 PM
Can we use the catchcan made for the G8? HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-05-2010 10:35 AM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
