09-25-2020, 03:20 PM | #1 |
Drives: 2017 Camaro 2SS Join Date: Jul 2016
Throttle Percentage
Hi all, need a little help. Took the car to the dyno the other day and was not happy with the results. Did a little logging today to see what I could find and noticed that my throttle percentage as displayed by the Aeroforce gauge never goes past 83% at wot no matter the gear. I'm new to the platform and was wondering is this normal or is there an issue with the tune and 95mm throttle body?
Thanks!
2017 2SS A8 TSP LT's, ported msd/95 mm, e85
09-25-2020, 06:24 PM | #2 |
This is normal. The gauge is probably linked to the SAE throttle position channel, and 83-84% is how far it goes even with the pedal to the floor. I'm not an expert, it looks like an endpoint calibration peculiarity with our cars.
09-25-2020, 06:55 PM | #3 |
That’s what my logs show too.
09-25-2020, 07:06 PM | #4 |
Thanks for the responses guys. Was hoping that was it but I'll keep working on it.
09-25-2020, 07:10 PM | #5 |
Post up a log and we can check it out
09-25-2020, 11:32 PM | #6 |
I'll see if I can get one from the tuner Monday, thanks! I did my logging today (if you even want to call it that) with the Aeroforce and don't have much info. Throttle percentage and knock retard only. I can measure some more perimeters with Torque tomorrow if that would do any good?
With the mods in my sig (on 93) the car only made 414 rw. This is on the dyno at the performance shop I work at part time. Been using it for years and it's spot on, but I was surprised that a ported msd, longtubes, tb and tuning would only net 414. Our tuner has been doing it for 25 years so I'd be shocked if that was the issue, but certainly can't rule it out. I'm kind of wondering if perhaps the torque converter is not in good condition. Car had the shudder real bad when I purchased it. No idea how long it was happening with previous owner. Dealer flushed and fixed but part of me is wondering if the tc needs replacing.
09-26-2020, 12:20 AM | #7 | |
If the shudder returns, you should push for TC replacement with the dealer. As far as I know, the torque converter locks up under load, so performance will only suffer if it's no longer able to, which would show in the logs as slip percentage.
09-26-2020, 12:25 AM | #8 |
Yeah that’s really low on any dyno with those mods. I don’t think a tuner could make up that much difference unless something was seriously out of whack, but there can definitely be a big difference between tuners on this platform. Even a lot of them that are normally great on LS motors don’t seem to get the numbers Pray or GPI do on these.
2020 ZLE Roto-Fab dry
2018 Camaro 2SS 1LE - 2" TSP catless headers, Pray Ported stock IM/TB, Rotofab dry, DSX FF kit, dyno tuned by Pray. SOLD |
09-26-2020, 10:35 AM | #9 | |
Would have loved to have gotten baselines but the shop has been slammed and I just couldn't wait for an opening to start the modding lol.
09-26-2020, 10:41 AM | #10 | |
Really trying not to get too worked up about it until I can get to the strip. Appreciate the help!
09-27-2020, 12:43 PM | #11 |
Drives: gas powered Join Date: Jan 2019
83% is pretty typical across all makes. It must be an OBD2 thing.
You can double check it using the voltage out put.
09-27-2020, 09:21 PM | #12 | |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
One way to tell is to somehow place a camera in a position to make sure your TB Butterfly is wide open when you step on it. Harbor freight sells the scoped cameras with the flexible tube for looking into crevices. |
09-28-2020, 12:36 PM | #13 |
Trying to upload a log file but it's .hpl format and the site won't upload it. Any ideas?
Thanks Jason
09-28-2020, 01:07 PM | #14 |
Drives: 2019 Camaro 2SS manual Join Date: Feb 2020
