Old 04-16-2021, 01:02 PM   #1
H4r0ld
H4r0ld's Avatar
Drives: 2019 2SS
Question Spark Plugs - What's the Difference?
Hi all,
I daily drive a relatively stock 2019 2SS and maintenance calls for a spark plug and wires replacement. I've done as much research as I reasonably can and settled on:
Holley MSD 33829 Spark Plug Wires:
https://www.holley.com/products/igni...ts/parts/33829
And
NGK Iridium LTR5IX-114344 Spark Plugs:
https://www.amazon.com/NGK-LTR5IX-11.../dp/B001MU28F2
My question is, will there be any noticeable difference in upgrading to performance wires/plugs compared to OEM?
(I realize this is kind of a silly question but I'm not much of a car guy. More like a computer nerd trying to learn cars. )
H4r0ld is offline   Reply With Quote
Old 04-16-2021, 01:06 PM   #2
H4r0ld
H4r0ld's Avatar
Drives: 2019 2SS
Also, is it advised to buy a gap checker and set a specific gap in the plugs or is out of the box gap okay?
Old 04-16-2021, 01:12 PM   #3
Jb54
Drives: 2019 Camaro SS M6
I think anytime you uprade components in the ignition system it's a ++ all the way around! When it comes to plug wires it's all about ohms(resistance). You chose wisely. MSG and NGK aretop brands. Just make sure the plugs are gapped to spec correctly before installing. I think you made some great selections. The combination will make a strong spark.
Jb54 is offline   Reply With Quote
Old 04-16-2021, 01:22 PM   #4
chevybill
Drives: 1994 z-28, 2017 2ss 6spd
To the OP,
How many miles have you accumulated that it's time for plugs and wires?
Amazon is calling that particular plug, a motorcycle plug.
chevybill is offline   Reply With Quote
Old 04-16-2021, 01:33 PM   #5
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Originally Posted by chevybill View Post
To the OP,
That is the correct plug. I checked the parts finder on NGK's website.
Plug gap is supposed to be 0.040 for non-supercharged. And you should check the gap as it may not be correct out of the box.
NGK it top shelf.
Spaceme1117 is offline   Reply With Quote
Old 04-16-2021, 01:42 PM   #6
H4r0ld
H4r0ld's Avatar
Drives: 2019 2SS
Yea, I saw that and verified on NGK's website. It doesn't let you link directly to the part though so I used Amazon's link:
https://ngksparkplugs.com/en/part-finder
I'm currently at 37,809 miles.
I just assumed it was about time but @chevybill, after your comment I checked the manual and it doesn't call for plugs and wires until 97,500 miles.
I'm really just doing maintenance for fun anyways.
It's currently sitting on jack stands with the wheels off. I'm doing some compounding & polishing getting ready to slap some ceramic coat on the body and wheels. It's at 20% oil life so I figure why not do the spark plugs and wires while I'm in there?
This is just a fun toy to mess with. I can't afford to buy all the racecar parts right away so I shoot for flawless show condition as much as possible in the meantime.
Old 04-16-2021, 04:32 PM   #7
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
To the OP,
This.
You don't need new plugs and wires unless your car is ancient.
Old 04-16-2021, 04:46 PM   #8
H4r0ld
H4r0ld's Avatar
Drives: 2019 2SS
Yea, I just assumed it was time. Cars used to require it around 30-40K miles but I guess the technology has improved.
Old 04-16-2021, 05:25 PM   #9
s346k
s346k's Avatar
Drives: like an old lady
cars have been on the 100k mile plug/wire interval for the last 20+ years.
there will be no noticeable difference in anything vs new stock parts. to each his own.
Old 04-16-2021, 05:45 PM   #10
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
Plugs and wires? Get out of the time machine and enjoy your modern car.
For the record I put NGK and everything I own, nothing comes close.
Zaqwert6 is offline   Reply With Quote
Old 04-16-2021, 06:02 PM   #11
FarmerFran
FarmerFran's Avatar
Check the gap and get a decent one. I like the blades not the round thing.
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top.
Old 04-16-2021, 06:25 PM   #12
Petrol Head
Drives: Fast if no one's looking
Cars ALL have AT MINIMUM 100,000 mile spark plug intervals today. Really for the last 25 years. In fact I’m certain the 4th Gen F-bodies had 105,000 spark plug intervals when they switched to the LS1 and 3800 in 1998.
Unless you’re driving 50,000 miles/year, you do not need new spark plugs now.
40k tuneups went out with carburetors
Petrol Head is offline   Reply With Quote
Old 04-17-2021, 07:16 AM   #13
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
I'd wait to 100k miles to change them, but if your going to do it anyway...
If you not a car guy, a few helpful recommendations from someone that has done his fair share of plugs\wires: use a hi temp anti seize compound on the threads prior to installing. You'll be happy you did when it's time for the next change and you'll never have to worry about a plug seizing or breaking off. Takeout one plug out at a time and dont let anything fall in that hole. If the plugs come with a crush washer put it on, then start threading it in with fingers (never with a ratchet or tool) to keep from cross threading. Then use a hand ratchet to finish it, never air or battery tools. Keep threading until it just bottoms out, then 1\2 turn and stop. If no crush washer. Use a torque wrench and tighten to spec.
For the wires, always change one wire at a time. Never take them all off at once.
Hope this helps.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 04-17-2021, 07:21 AM   #14
Camaro fanboy
Camaro fanboy's Avatar
Drives: 2017 2SS Arctic blue fully loaded
yep
spark plugs every 97 000 miles.
Camaro fanboy is offline   Reply With Quote
