06-12-2022, 07:40 AM | #1 |
No lift shift???
Is this factual? No lift shift above 5000rpms
Or is it BS? |
06-12-2022, 07:54 AM | #2 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
06-12-2022, 07:55 AM | #3 |
100% factual: https://www.camaro6.com/forums/showthread.php?t=513327
06-12-2022, 07:56 AM | #4 |
I'll answer the way I do when my wife asks two questions back to back. Yes and No.
Just joking - The answer is yes NLS is enabled at 5000 rpm.
06-12-2022, 08:48 AM | #5 |
Ok, so how does it work mechanically? Gears are cut
To accept this?, Ignition is momentarily shut off? |
06-12-2022, 09:14 AM | #6 |
Did you read the links posted above? It’s explained pretty in depth.
06-13-2022, 08:37 AM | #7 |
Read the link, so it’s all computer, that keeps
The trans from not “grenading”,interesting. |
06-15-2022, 06:31 PM | #8 |
Drives: like an old lady Join Date: Jun 2012
to be fair. every manual car is equipped with no lift shift. my 94 m6 z28 had it.
06-15-2022, 10:44 PM | #9 |
Drives: 2020 Camaro ZL1 Join Date: Jun 2022
06-16-2022, 07:52 AM | #10 |
Drives: 2004 Z06, 2017 1LE Join Date: May 2017
06-16-2022, 02:57 PM | #11 |
i think the old term is power shifting. my cars never hit the rev limiter. hard on synchros tho.
06-16-2022, 03:31 PM | #12 |
Drives: 2022 ZL1 Join Date: May 2019
You're still fully disengaging the clutch, so it's no different than running up in the RPM and then shifting. There's no extra resistance and the transmission is not under load. The rpm adjustment for the next gear by the electronics allows a near seamless shift when releasing the clutch quickly. As long as the gear oil in the transmission is up to temp, the synchromesh isn't bothered by this. This transmission was designed for shifting quickly, so no force needed.
The main advantage is the seamless shift without upsetting the suspension. That should also indicate that the clutch isn't getting heated up getting the engine up to speed with the transmission and vice versa. |
06-16-2022, 06:28 PM | #13 |
Ok…. The title of my post, “ no lift shift “
Meaning, wide open throttle,” Clutched up shift” Ok,I was getting that confused with my motorcycles Which have clutchless upshifts, which need a modded Gearbox. My bad |
