01-16-2020, 07:46 PM | #1 |
Drives: 2016 Camaro SS Join Date: Jan 2020
Spark knock with recently purchased 2016 SS
I just bought a 2016 SS with an A8 that only has 24K on the odometer. The car looked super sweet from the highway so I stopped and checked it out. Four hours later I bought the car after some serious negotiating on both sides. I specifically told my salesman to NOT put any more gas in the car if they weren't going to use 93 octane. He insisted they did so I took his word over it. But I quickly noticed some spark knock right after I left the dealership and that has me wondering. Did my salesman lie about using 93 octane or worse, does my new baby have an issue with spark knock that I need to worry about? I've been driving as much as I can so I can drain the tank down to almost zero so I can refuel the tank with the same 93 gas I've been using for years and years....
I'm seriously hoping the salesman lied to me about using 93 octane which should explain the spark knock..... |
01-16-2020, 07:53 PM | #2 |
Drives: SS 6 speed of course Join Date: Jan 2016
same thing with my new Camaro, dealer filled it with cheap stuff even though I was specific about my free tank full, car ran poorly, I filled 1/2 tank of 93 half way home and it was better. Dealers are MORONS.
01-16-2020, 09:53 PM | #3 |
These engines show spark knock on 93 with the stock tune. The knock sensor thresholds are set very aggressive due to the high compression and being a fail safe in the likely hood that somebody puts low octane fuel in.
2016 NFG 1SS A8
01-17-2020, 05:24 AM | #4 |
Drives: 18 Camaro LS M6 Join Date: Apr 2019
same experience on a new 18 hold over 2turbo. but yours has miles. don't get too freaked out run it down and refill with 93. it should "re-calibrate" over time. you can do a dose of over the counter anti-knock stuff it does work in the short term. you might want to see if the dealer can probe the ecu and see if its ever been flashed. that would be interesting to see what comes of that and what their response is.
. . NFG M6 2T Mishimoto Hot side pie | ZZP Catted DP | KN Drop in | Borla - Sport Tour | Apex Arc 8 - square | Wookster Tuning+ | Flex Fuel Last PB 4.8, 13.2@106 |
01-17-2020, 09:58 AM | #5 |
Drives: Chevy Camaro Join Date: Jul 2019
How do you know you have spark knock?
01-17-2020, 11:40 AM | #6 |
With software that monitors and logs data from GM parameters inside the ECU.
You can use HPtuners scan software P3 guage(there are others) Torque pro app on a smart phone with a obd2 Bluetooth device Several different options
2016 NFG 1SS A8
01-17-2020, 11:55 AM | #7 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
01-17-2020, 12:07 PM | #8 |
I think what he's (ssmofo) asking is "how does the OP know he has spark knock?" not how to do it. The OP made it sound like he heard it while driving. He didn't say anything about seeing spark knock in a datalog.
01-17-2020, 01:21 PM | #9 |
Drives: 2004 Z06, 2017 1LE Join Date: May 2017
OP, are you sure what you heard is spark knock, and not the noise from the Direct Injection system?
01-17-2020, 01:55 PM | #10 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
if it is true detonation you will hear it, especially when you are driving up against concrete barriers. Otherwise if it is bad enough it can make the check engine light flash. Only other way is to data log the ECM.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
01-17-2020, 02:38 PM | #11 |
It was pinging and it ran poorly under light load highway speeds. I had to use 5th gear to get a little bit more rpm and less load. I live through the energy crisis I know poor quality gas and high compression pinging sounds like.
01-17-2020, 07:23 PM | #12 |
Yea you are probably right...I was assuming that the OP used a scanner to verify it was knock retard.
2016 NFG 1SS A8
01-17-2020, 10:36 PM | #13 |
Drives: 2016 SS Join Date: Jan 2016
Dealers always lie and put cheap gas in new cars
01-17-2020, 11:10 PM | #14 |
Yes, I can definitely hear the spark knock for which I definitely know what spark knock sounds like. I use to own two '87 Buick Grand Nationals. Hearing any spark knock on those cars back in the day was very, very bad. I'd have to think it's nowhere near as bad on a naturally aspirated engine though.
