04-21-2018, 01:36 AM | #1 |
Drives: '18 SS 1LE Join Date: Jul 2016
Block gasket surface clean enough?
I've been trying to clean the head gasket mating surface on my block for an hour now, heads are already pretty clean.
I'm looking to put the heads back on right now. Can somebody please give me an opinion if this is clean enough, or should i put another hour in? https://imgur.com/gallery/Oltdwb7 |
04-21-2018, 03:30 AM | #2 |
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi Join Date: Apr 2009
No LS experience but plenty of engine experience. I have never assembled one that looked like that. I always had them much cleaner. I put paper towels in the cylinders and run a fine stone in them with oil.
04-21-2018, 03:54 AM | #3 |
Okay i cleaned them for another hour. the shadows in that picture made it look much worse than what it was.
Theyre not spotless, but im fairly confident with what i have now. |
04-21-2018, 08:35 AM | #4 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
scotch pads and brake cleaner...should be bright and shiny...peace...
don't forget to chase the head bolt holes!
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
04-21-2018, 08:36 AM | #5 |
Drives: 2012 SS/RS MN6 Join Date: Mar 2016
Keep going.
04-21-2018, 10:05 AM | #6 |
Drives: 2015 Camaro 2SS Join Date: Oct 2016
Keep at it.
Here's mine, which took forever, but its a job you don't want to do twice. http://www.camaro5.com/forums/showthread.php?t=488633 |
04-21-2018, 11:23 AM | #7 |
Drives: o Join Date: Jun 2017
Yeah they should look like Gordos.
No air tools? You can use a scrubby pad. Lots of finger pressure. Should be able to clean up in an hour or less. |
04-21-2018, 12:01 PM | #8 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
When in doubt, keep at it. It is better to overkill than the opposite.
04-21-2018, 01:55 PM | #9 |
https://imgur.com/gallery/JXFAzyh
Still a little residue, no chunks. feels smooth to the touch. I've heard some bad things about using scotch brite. Didn't know this was gonna be so tedious! |
04-21-2018, 06:30 PM | #10 |
RTV silicon on gasket surfaces of block and head with gasket sandwhiched between shouldn’t be a problem if they’re decent no?
Life is short, drive it like you stole it! |
04-21-2018, 07:24 PM | #11 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Razor blade and brake kleen. No scotch brite (micron size of Scotch Brite was the concern). Discussed this with Ryan at GPI and that is what he recommended. Used a ‘rough’ edge blade so not to gouge. Ryan reviewed my pics, said good to go. Don’t forget to clean out the head bolt holes.
https://www.camaro5.com/forums/showt...=385577&page=7 25k miles on boosted engine with no issues. GPI sold my old engine and it’s still running... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
04-21-2018, 07:38 PM | #12 |
thanks guys. heads going on right now.
