Old 04-05-2018, 12:23 AM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Coilovers or Factory (1LE strut) setup?
I am trying to decide what to change my existing stock setup (Besides BMR Lowering springs) to. I am not looking to spend more then necessary as the vehicle isn't/won't be seeing any track time.
Nighthawk89 is offline   Reply With Quote
Old 04-05-2018, 11:16 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
If you won't be going to the track and don't want to spend more than necessary then your stock parts are all you need . If you want an improvement then I would go with either 1LE or Bilstein's B6's - whichever's cheaper; better coil-overs will be even more $.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 04-06-2018, 03:13 PM   #3
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Shop around and look for deals! I got my 1LE shock/strut setup for $200 shipped, and they had 19k miles on them.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 04-15-2018, 10:14 PM   #4
Devcon 7
Devcon 7's Avatar
Drives: 15 camaro
Did lowering your car hurt it's ability to hook?
Devcon 7 is offline   Reply With Quote
Old 04-16-2018, 09:06 AM   #5
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Also, how do you like the BMRs? Any track time with them?
wakespeak is offline   Reply With Quote
