02-21-2017, 03:22 PM | #1 |
Drives: '14 Camaro SS L99 Join Date: Feb 2017
Battery Died after dyno tune?
Hello guys, i truly need your help as i do not know what went wrong...
So i just installed some LT headers and everything was fine, i went to dyno tune it afterwards and everything went smoothly, however after the dyno tune was done i went to start my car up but it refused to start i called the tuner and asked him what was wrong he said the battery is probably dead, i asked how come? and he said its probably used too heavily and just gave up and needs replacement ( which i seriously truly doubt it because for the past 3 years i had my car i always took good care of it and never had any issues with the battery) So my questions are: 1. what caused the battery to die after the tune? was it the tuners fault? or did just coincidentally give up at that time (although i really doubt it) 2. if it was the tuners fault and lets say the battery couldnt handle the power the tuner tuned it at, would another battery also die after i install it? or would it be fine? Thank you so much guys, please help me i really need your opinion on this and please tell me if you faced something similar like this. Thanks again. |
02-21-2017, 03:23 PM | #2 |
Btw, my car is completley STOCK ... the only mod is the LT headers, connected to the stock catback ... im also an automatic (L99) if that makes any difference.
02-21-2017, 04:25 PM | #3 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
The tuner doesn't adjust any part of the alternator output or battery. I would check to make sure all your grounds are good then have the battery tested. It's possible that the key was just left on and forgotten about.
02-21-2017, 04:46 PM | #4 |
Drives: 2010 camaro ss Join Date: Jun 2010
My OEM battery lasted about 3yrs. Get it tested. It's free
02-21-2017, 09:09 PM | #5 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
any auto parts store can check it for you, autozone, o'reilly's, advance just to name a few
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
02-21-2017, 10:06 PM | #6 |
Drives: Black L99 2SS/RS Join Date: Mar 2014
I don't know what the hell a dyno tune has to do with ruining someone's battery.
Shit he probably swapped your battery out for a pos battery he's had laying around. |
02-22-2017, 02:31 PM | #7 |
Drives: 2011 camaro ss convertible Join Date: Oct 2015
When i got my car I used it for a year and a half with absolutely no problems or trouble with the battery (my car was 4 years old at this point and had the original battery) and all of a sudden one day when i woke up and went to start the car it didnt want to start, it turned out to be the battery that died on me literally over night because I had used it the day before and it didnt give no warning or signal. I replaced the battery and everything was back to normal, so i would say it was just coincidence
02-22-2017, 03:04 PM | #8 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
A lot of times you read and write the car with the car off but the key-on. It's possible that the battery just needs a little charge, or a jump and could be working like normal after that and the alternator gets the charge up.
Doesn't take much to get a battery tested
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
02-22-2017, 04:02 PM | #9 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
3 years...might be time for a change
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
02-22-2017, 04:05 PM | #10 |
Drives: 2010 Camaro SS (RS LS3) Join Date: Dec 2015
I'm running my original Delco. Car was produced in 2009 😂
I can notice it's going to die sometime soon due to kinda weak morning starts Sent from my ONEPLUS A3000 using Tapatalk |
02-22-2017, 08:05 PM | #11 |
Drives: 2018 Camaro ZL1 1LE Join Date: Apr 2015
My battery died after a year. I drove the car for a hour, turned it off to get a coffee and came back and the battery was dead and wouldn't turn over. My battery did die a couple times in the year from it not being drivin. Yours probably has a bad cell.
02-22-2017, 08:13 PM | #12 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
If your car is still under the 3yr/36k warranty go get a new battery from the dealership. I just did that a few weeks ago
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
