02-11-2017, 08:52 AM | #1 |
Drives: 2011 Camaro 2ss Join Date: May 2015
Throttle Body Help
I have been getting the P2135 code, and occasionally PO121, and my Camaro has been going into reduced engine power mode. When I tried to figure out what it was no one had a straight answer of what could fix it so I decided to start with replacing the throttle body. Throttle body works fine but when I go to shift it still revs up as if I am still pushing the accelerator. Also when I come to a stop in neutral the car wants to rev up to 2 rpm until I am at a complete stop, if I stay in gear and stop it wants to go to 1 rmp. Any ideas on how to fix this? I tried doing a relearn without a scan tool, I will try today with it though to see if that helps, but my next step would be to replace the accelerator position sensor and see if that helps. Any ideas would be appreciated, thanks!
02-11-2017, 11:08 AM | #2 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
02-11-2017, 11:09 AM | #3 |
Resident nomad
Or these...
http://www.camaro5.com/forums/showth...ighlight=P0121 http://www.camaro5.com/forums/showth...ighlight=P0121 If you can find a donor TB, you can troubleshoot that quickly. You could swap it out in a few minutes, easy peasy.
Sold:
02-11-2017, 11:41 PM | #4 |
Ammo
Drives: 2010 Camaro 2SS/RS (LS3 M6) Join Date: Aug 2013
Its the throttle position sensor on the pedal (70 dollar part) that is going bad (at least it was for me). Replaced the pedal, and havn't seen the issue since.
02-23-2017, 04:19 PM | #5 |
Thank you guys for your help! I will be trying the position sensor next..fingers crossed!
02-23-2017, 04:25 PM | #6 |
Seem all GM products do this. Happened on my prior company car impala and truck z71.
Car mods: never enough!
02-23-2017, 04:35 PM | #7 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Not just chevys , dodge trucks it's very common for the pedal sensor to fail and get a limp mode too
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
02-23-2017, 06:10 PM | #8 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
Do you have a throttle controller? Vitesse or similar?
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
02-23-2017, 06:32 PM | #9 |
New pedal for sale for op. Couldn't send on private message...
Thread Tools | |
