04-30-2024, 01:54 AM | #15 |
Long hauler
I'm at 23k miles now, it's why I'm not doing anything to the car until my 6-year/100k mile CPO Powertrain warranty is up
2016 1LT v6 - Totaled Happiness: Infinite |
04-30-2024, 05:48 AM | #16 | |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
04-30-2024, 12:11 PM | #17 |
Electrical Engineer
I posted descriptions of the AFM system in detail in this thread: https://www.camaro6.com/forums/showthread.php?t=617893
There is not a consensus that having a manual or having a range module saves you from lifter failures. Wherever you go online (this forum, Reddit, FB, etc) you will find folks stating that lifter failures occur due to the lifter design and have occurred on manuals and AT with Range modules installed. I've looked for more conclusive information on details surrounding failures (oil type used, mileage, was it downshifting, was it transitioning from V4-V8, etc.) but haven't seen much info.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
05-01-2024, 10:34 AM | #18 |
Drives: '16 2SS M6 Join Date: Aug 2019
136k miles here. No issues
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
05-01-2024, 10:39 AM | #19 |
Don't tread on me
Drives: 23 Sierra X31, Past 2017 Fifty 2SS Join Date: Nov 2012
AFM/DFM have caused issues since 2008. It's for emissions. If it weren't for that, these engines would continue to be as rock solid as the ones still running like a top today. You cannot kill a cateye 5.3 especially, they'll outlive the vehicle themselves.
05-01-2024, 10:55 AM | #20 | |
Drives: 23 2SS 1LE Join Date: Feb 2019
The problem is the lifters, not the AFM system. From everything I read on it, the AFM system can cause premature failure, but is certainly not the only cause. Don't think that because you have a manual or a range device that you are now immune to having lifter failure.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
05-01-2024, 04:26 PM | #21 | |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
This is the only guaranteed solution. Everything else is hopes and dreams. My 19 Z06 runs out of powertrain warranty later this year. It’s headed to Katech for heads, lifters etc. My 16 Z51 was a 7 speed manual. Don’t kid yourself, not an auto-only issue. I picked up that car with 3 miles on the clock. That car had never been in V4 mode, ever. At 7,200 miles, bank 7 lifters failed. Scored the cam. GM fixed it under warranty, but dumping the factory garbage is the only right answer
"Make yourself sheep and the wolves will eat you"
05-01-2024, 04:32 PM | #22 | |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
05-01-2024, 06:45 PM | #23 | |
Electrical Engineer
Another factor is 5W-30 vs 0W-40 Supercar. The engineers made that change for a reason and it wasn't saving money. I've seen discussion where the engineers stated they always wanted it but it took years to get through paperwork and legal. Folks with Camaros still argue that oil is oil and the Engineer's don't know what they are talking about, it's all about money, etc. I get that a $120-$150 oil change every 5,000 miles isn't cheap, but it's cheaper than owning an exotic car.
05-01-2024, 08:31 PM | #24 | |
Long hauler
Same oil & filter part number for 0w-40 used all times
05-01-2024, 08:44 PM | #25 |
Drives: People crazy with my sexiness Join Date: Jun 2023
It would have been hilarious if someone brought their own cam/lifter kit plus all their tools and Jack the day they picked up their new Camaro then change the kit out right there in the parking lot before driving it home.
The thought actually crossed my mind.
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023 2024 2SS 6MT coupe Sharkskin/Light gray Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers Gray painted split spoke wheels Illuminated footwells/illuminated bowtie |
05-01-2024, 09:25 PM | #26 | |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
For what it's worth, even the afm cam and lifters, by and large, are more reliable than any .600 + lift aftermarket setup. There is maintenance associated with those, which is fine if you're aware and prepared to deal with it. I'll guarantee you the aftermarket setup is not going to go 150 - 200k miles without attention. The oem parts usually will.
Baby Blue
05-01-2024, 09:35 PM | #27 | ||
The failure rates are nowhere near as bad as when GM first kicked off this DOD bullshit, but again, the only real remedy is removing the cancer altogether.
05-01-2024, 11:06 PM | #28 | |
Long hauler
