Old 11-28-2023, 07:35 PM   #29
MyNameIs
Drives: Camaro SS
Just put some mileage on your cars, make sure it experiences bitter cold and extreme heat to stress the metals in the muffler the crackles and pops will subside.☝️��
MyNameIs is offline   Reply With Quote
Old 11-29-2023, 05:10 AM   #30
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
What if I donít have a muffler
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
FJB
Dynamical is offline   Reply With Quote
Old 11-29-2023, 05:16 AM   #31
Dynamical
Dynamical's Avatar
Originally Posted by Chutzpah View Post
While I somewhat agree with your sentiment, the shotgun blasts can be a bit rediculous. I honestly wouldnít blame those that are annoyed by them to throw their hands in the air and tune them out. Chevy should have simply added a software setting to de tune them.
That said, the 19+ LT1 engine does it way more than any year LT4 or 16-18 LT1.
I spent good $ for an axle back, that I wouldnít have otherwise, just so I could enjoy getting on the gas without sounding like an obnoxious menace. Now I just sound like a menace
What axleback do you have? You get the drive by shooting effect too?
FJB
Old 11-29-2023, 05:31 AM   #32
Dynamical
Dynamical's Avatar
Originally Posted by ZR1-OK View Post
Thatís it - just tune it out screw with your car and void your warranty
Maybe, maybe not. Although I did buy my car for modding, I did not want to lose my warranty. But I still have a few years left and doubt Iíll be able to hold off. Depends on what people want for their own cars. If the shotgun blasts were that bad and wanted to keep warranty, I could put the stock muffler back on or keep very light throttle instead of letting off the gas 100% which tames the street gang from doing their drive by
What do you have for exhaust? Chances are, if you had a AWE track which is a straight piped muffler delete you could relate more.
This axleback is much more enjoyable than something I dislike, so itís not a huge issue for me
FJB
Old 11-29-2023, 10:08 AM   #33
CamaroChk
CamaroChk's Avatar
Drives: 2018 2SS Camaro
My 2018 still pops and crackles, im in Iowa and my car isnt garaged. Extreme heat and cold. It however has only ever popped and crackled in manual mode when downshifting.
CamaroChk is offline   Reply With Quote
Old 11-29-2023, 12:02 PM   #34
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Corsa Sport
Old 11-29-2023, 07:11 PM   #35
JonR
JonR's Avatar
Drives: 2023 Camaro 2SS 1LE
I’m so surprised that most of y’all don’t like the pops and burbles. Personally I love it.
So if I understood this thread right, does an axle back system reduce the burbles?
JonR is offline   Reply With Quote
Old 11-29-2023, 10:53 PM   #36
JT6Speed
JT6Speed's Avatar
Drives: 2023 Camaro 1SS M6
I don't mind the pops, and with a manual it's not hard to "drive around" them. If you avoid rev-matching when it will kick up the rpm's too high, you barely get any pops. I usually come to a stop in neutral or just clutch in and brake, which makes the car literally silent. If you're driving a little more spirited and hit some downshifts to accelerate then it becomes more noticeable. Overall though the stock NPP has a damn good tone imo.
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022
-Dual-Mode Exhaust (NPP)
-Red Painted Calipers (J6F)
-5 Split Spoke Bright Silver Painted Aluminum Wheels (56W)
-Chrome Camaro Logo Fender Badge
-Second Generation Front Splitter in Satin Black
JT6Speed is offline   Reply With Quote
Old 12-02-2023, 07:19 PM   #37
MyNameIs
Drives: Camaro SS
How many miles on it?
Old 12-02-2023, 08:18 PM   #38
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
my 2023 ZL1 crackles like crazy bone stock. My 2017 Fifty Edition Camaro SS popped a ton as well but not as much as my ZL1.
It is all in the tune. There are quite a few things done on the ZL1 tune by GM to make it crackle a lot more. Some of the settings cannot be seen without some custom user defined parameters being exposed.
Old 12-02-2023, 11:40 PM   #39
Seventh Camaro
Seventh Camaro's Avatar
Drives: 2022 Camaro 2SS
I also have an M6 and pretty much have it figured out how to drive around them. Mine pops pretty hard during shifts when lifting off the throttle, but the RPM range for the pops seems pretty tied to 2000-2500 RPM range. When shifting from 1st to 2nd, and second to third, I shift right around 2500 to bypass them. If I'm just doing my local cruse, right after I have shifted to 3rd, I shift to 4th at 2000 and am cruising in the 40-45 MPH range. Hardly ever with that pattern does my car pop. If I do my shifting anywhere between 2000-2500, pops are plentiful. They do seem more pronounced when the car is cold. I also tend not to downshift much during normal driving when slowing down, as I was taught that wasn't as healthy for the transmission. I don't have experience with the A10 in a Camaro to know what conditions create them. I have the Flowmaster NPP axle back and drive in sport mode most of the time. I couldn't really tell a difference in the amount of crackle and pop noise when going from stock NPP to the Flowmaster. Flowmaster did increase the volume of the exhaust I'd say 15-20 percent at a guess, for sure made the tone a little deeper. I'm an old guy so I like the Flowmaster tone.
Seventh Camaro is offline   Reply With Quote
Old 12-03-2023, 12:06 AM   #40
BMLMZ
Drives: 2022 Camaro ZL1
Pretty sure its all done right here...
BMLMZ is offline   Reply With Quote
Old 12-03-2023, 02:14 PM   #41
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
no its not
Old 12-03-2023, 03:40 PM   #42
IIRC it's done in the minimum final spark table.
2018 Camaro 2SS ó G7E MX0 NPP F55 IO6
