06-11-2020, 07:48 AM | #1 |
Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
Differential fluid question
It has came to my attention that there are 2 different bottles of rear diff fluid with the same part number 10-4034. One of the bottles has GL5 on it and the other one doesn't. Does anyone know if it is the same fluid and different bottles. i have searched here and the corvette forums but no definitive answer was given other that GL5 is a pressure rating.
OEM part number is= 88862624. There’s a similar part number= 1#88862624. Bottles looks almost the same except the 1# part number bottle doesn’t say GL5 on it. Both carry the same ACDELCO number 10-4034. I wonder if there’s a difference?
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
06-11-2020, 08:07 AM | #2 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
I Google'd this 75w-90 gl-5 and found something this, maybe the same thing you saw:
High-Grade Automotive Gear Oil (GL-5) GEAR OIL GL-5 is a high-grade automotive gear oil made from highly refined base oil and top-performance extreme-pressure agents, metal anticorrosion agents, detergent-dispersants and other additives. It meets the API service classification grade GL-5. There was even past Camaro 5 threads mentioning this GL-5 fluid but nothing that really stood out as whats the difference. If no one gives a good reason on why the GL-5 would be better then I'd just get the non GL 5 fluid and continue using that one. |
06-11-2020, 08:10 AM | #3 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I found that the dealership was the only place I could find the recommended OEM part 88862624 and the other one 1#88862624 was more widely available. I was hesitant to buy the latter because it doesn’t say GL5 on the front label.
06-11-2020, 10:20 AM | #4 |
You can easily find 88862624 on Amazon. It's where I purchased mine from.
06-11-2020, 10:26 AM | #5 |
From BOBISTHEOILGUY forum:
GL-5 is for hypoid gears which is what you have. https://www.oilspecifications.org/api_gos.php The bottle with GL-5 is the just a change in the label. Both are GL-5.
06-11-2020, 10:35 AM | #6 | |
06-11-2020, 12:41 PM | #7 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
06-11-2020, 01:33 PM | #8 | |
Drives: CTV5 V Blackwing on order Join Date: Feb 2020
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10 2017 Ford Expedition |
06-11-2020, 01:39 PM | #9 |
probably not but ZX-10R is a big proponent of using aftermarket fluids due to the mark up due to licensing fees for Dexos certs ect:
06-11-2020, 02:45 PM | #10 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
IIRC 88862625 is the GM Canada part # and is in 1 litre bottles
06-11-2020, 04:08 PM | #11 |
06-11-2020, 05:10 PM | #12 |
