Roto-Fab
Old 03-08-2021, 09:54 PM   #1
Hemo
Drives: Camaro 20133
Exclamation Radio issue 2013 camaro
Hi everyone,
I have an issue with my 2013 camaro 90k miles. The problem is about hearing a pop sound that comes from speakers. The sound appears and disappears in less than a second. After that, the radio is not working, even when i change the radio channels. I have to turn off the car, then turn it on to have the radio working again. Any help please?
Hemo is offline   Reply With Quote
Old 03-10-2021, 02:53 PM   #2
ASC08
Drives: 2014 1LS
I am having a similar issue in my 2014. Someone indicated on a previous post from several years ago that there were several 'bad solder joints' in the radio that could be repaired.
Anyone know if there are typical culprits, or do you need to do a careful inspection to find the bad solder joints?
ASC08 is offline   Reply With Quote
Old 03-11-2021, 03:44 PM   #3
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
44 way black connector at the back of the radio
White wire(remote enable) circuit 7066 in position 43
cut this wire about an inch from the connector and try it.
looks like its the only all white wire, the other whites have tracers
cavity 44 should be red/blk and 42 should be brown or brown/wht.
Mouse330 is offline   Reply With Quote
Old 03-11-2021, 04:32 PM   #4
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Get a Corsa Extreme exhaust system. Problem solved.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 03-11-2021, 04:39 PM   #5
LFX Camaro
Drives: 2013 Camaro 1ls
I had this issue 2 years ago and ended up replacing the radio with another one I bought off ebay( I think the new one came from a chevy cruze). I just had this one start to go bad, not sure if my car has an underlying issue or just bad luck with radios. If you search it on YouTube you will find videos on how to remove and replace the radio. Not a hard job, but difficult to pull the radio face.
LFX Camaro is offline   Reply With Quote
Old 03-11-2021, 05:19 PM   #6
Shan
Shan's Avatar
Drives: 2013 ls Camaro
Originally Posted by Hemo View Post
Hi everyone,
I had that problem so I took it to the dealership & they diagnosed it & it was the radio itself they replaced it & I’ve not had any problems ever since! I had an extended warranty so I only payed $100 if not it would have cost me $850!!
Shan is offline   Reply With Quote
Old 03-16-2021, 02:25 PM   #7
ASC08
Drives: 2014 1LS
That did the trick.
Old 03-25-2021, 02:02 PM   #8
Mouse330
Mouse330's Avatar
good to hear
