03-03-2021, 09:39 AM | #1 |
Drives: 2013 SS Join Date: May 2013
Frankenstein/RK Speed Monster Heads
$2,750.00 FED .700" Dual Springs w/Ti Retainers, No wait time (4) sets left
03-04-2021, 08:50 AM | #2 |
Hello, couple of questions sir, I have been thinking about a set of heads and have heard good things about these. First will these work on my LS3 converted big cammed L99 engine, and if so will my stock rockers and updated bronze trunions and 7.40 pushrods work as well. And second, what valves, springs, retainers,locks, seals and guides are installed in these heads. Like I mentioned I've been looking and these aren't much more than the AFR'S and PRC 260's I have looked at. The reason I'm interested is I have a goal of trying to get to 500rwhp, or a bit more NA'd. Thanks for your info..
03-04-2021, 03:50 PM | #3 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Do you loose some bottom end with these heads ? If so , would using a thinner head gasket help alleviate that for a better quench and compression bump ? Of course checking ptv clearance
03-05-2021, 08:31 AM | #4 | |
03-05-2021, 08:34 AM | #5 |
below 3500rpms on LS3 they loose very little and gain from there. Thinner gasket will help both lowend and topend. If you have gears and a converter you will never feel the lowend loss.
03-05-2021, 08:58 AM | #6 |
Updated (2) sets left
03-10-2021, 04:57 PM | #7 |
1 set left
03-10-2021, 10:07 PM | #8 |
Drives: 2015 Chevy Camaro 2SS Green Flash Join Date: Oct 2017
Pm sent
03-16-2021, 09:28 AM | #9 |
4 more in stock
03-16-2021, 03:34 PM | #10 |
Drives: 2015 ZL1 Join Date: Aug 2016
How would these work on an LSA ? Stock blower just pulleys .
Also looking to do a supporting cam & injectors ?? |
03-17-2021, 09:09 AM | #11 |
They do great for LSA builds. Depending on supporting mods you can expect roughly 40-60whp gains. We have had customer report back 42whp gains on stock cammed ZL1's and 66whp on cars with pulleys 2" headers and a cam. Will make your combination more efficient.
03-17-2021, 06:59 PM | #12 |
Question that you didn't answer for me on my last post, will my stock rockers with the bronze bushing upgrade and the cromoly 7.400, 3/8" pushrods work with these heads? Just making sure before I pull the trigger, as I hear good talk about these heads on the forum. Thanks.
03-18-2021, 10:22 AM | #13 | |
03-18-2021, 03:31 PM | #14 |
Thanks for the info, just what I needed sir. Appreciated..
