12-06-2020, 04:43 PM | #1 |
Drives: 2018 camaro ss 1le Join Date: Nov 2020
What else do these cars need to get ready for the track?
how is the stock brake fluid and pads? I know the pads cannot be real track pads because they are way to quiet for the street. Ive had a few track days and tons of autocross under my belt. will i overheat the pads on track? i have never tracked a car this heavy before and i do not want to ruin a track day because of fade.
1LE Coupe 6M
www.usdashworks.com |
12-06-2020, 06:00 PM | #2 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
Done. Oh, yeah. 1500 mile break in, a diff fluid change, and bed the pads.
'18 1SS 1LE Black, PDR
12-06-2020, 06:38 PM | #3 |
What Boost Creep said.
I did Castrol SRF and GM Track Alignment. Ready, Set, GO! |
12-06-2020, 07:20 PM | #4 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
OEM pads are magic. Best all-around pad I have ever used.
Like others have said, fluid (I use SRF, also) and alignment.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
12-06-2020, 09:02 PM | #5 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Max front camber.. should get -2.4or so, -1.5 rear.. srf done.
2017 1LE Hyper Blue
12-06-2020, 09:35 PM | #6 |
Follow the Track prep guide and it's good to go. Track alignment is optional if you don't track very often, oil and brake fluid are not. Recommend SRF brake fluid and do a flush including ABS. Also change the trans and diff fluid if it hasn't been done lately.
https://camarosofmichigan.com/2018/2..._guide-min.pdf |
12-07-2020, 09:21 AM | #7 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
And, of course, echo all the recommendations per the above, plus bedding in the pads (but that goes without saying). Btw ive always used Frodo's recommendation per their website vs GM's (which seems a colossal overkill imo). |
12-07-2020, 10:12 AM | #8 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Ditto what others are saying; only need break-in, fluids, and alignment per the track prep guide. OEM pads will be just fine on track.
2017 SS 1LE.
12-07-2020, 01:30 PM | #9 |
Drives: 2018 1SS 1LE Join Date: Apr 2018
The Chevy track prep guide is pretty conservative on the camber numbers. Most have found maxing out the front as PBS up there said will work best. The front will usually max between -2.4 and -2.6. -1.6 seems to work really well on the rear.
2018 1SS 1LE (sold) |
12-07-2020, 01:42 PM | #10 |
dont forget to check your trunk for a towhook or order one!
12-07-2020, 06:48 PM | #11 |
kropscamaro16 has a good point, make sure you have the GM or good aftermarket tow hook like ZL1addons and its installed before you go out on track. Most groups require one.
https://zl1addons.com/collections/camaro-tow-hooks |
12-07-2020, 10:55 PM | #12 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
All you need is a good driver...
12-08-2020, 02:10 PM | #13 |
and some trackarmour or ppf and sticker numbers !
