10-08-2020, 07:18 AM | #1 |
Streetkingz_chri55
Aftermarket heads vs ported stock
Currently I have gpi ss4 nfc and looking to go 415ish and eventually boost it.. this next year coming up in looking into upgrading my head and intake and would like to know what is the pros and cons to aftermarket heads to ported heads. Especially since I'm going to be stroking it soon. Is spending the extra money going to net me a noticeable gain. Do anyone no roughly what the difference will be. Etc
10-08-2020, 07:47 AM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
For the money I wouldn’t go aftermarket on a street car. Only when trying to squeeze out every last pony. I’ve seen plenty of factory castings push north of 1200 hp.
10-08-2020, 08:22 AM | #3 |
Streetkingz_chri55
10-08-2020, 08:48 AM | #4 |
Drives: 2011 Chevrolet Camaro 2SS/RS Join Date: Jun 2020
While I have similar intentions as you, I went ahead and ported my heads through GPI before doing boost (still saving up for that). GPI did a killer job on the porting and it made a nice difference on the butt dyno for me along with a dialed-in tune. In hindsight, I would’ve started with boost before heads, cam, and stroking. I do feel good knowing that when I do boost, I’ll have a lot of efficiency =less heat but for the money I would’ve started with boost so save for them instead of heads. Hope that helps!
10-08-2020, 09:31 AM | #5 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
If going with boost, save your money put it towards the FI and fuel system. You can go incredibly far on the stock heads.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
10-08-2020, 09:53 AM | #6 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
What was said above...
For reference I just sold a set of used heads off a ford 416W for $2000. These heads flowed just slightly less than stock LS3 heads. The design of the LS heads really upped the game in cylinder head flow.
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
10-10-2020, 11:44 AM | #7 |
Streetkingz_chri55
10-10-2020, 11:45 AM | #8 | |
Streetkingz_chri55
10-10-2020, 01:06 PM | #9 |
Drives: 2010 Camaro 2SS Join Date: May 2016
Ok here’s my advice.Fig out what your goals are.
If you are trying to get every last hp when tuning for premium fuel etc.Then aftermarket are the way to go.Also the way to go if you are doing a big cubic inch build. If you have settled on running meth or e85 go with stock ported or just stock. So it just depends upon what your goal and setup will be in the end. |
10-11-2020, 06:20 AM | #10 | |
Streetkingz_chri55
10-11-2020, 04:58 PM | #11 |
Some aftermarket heads have a decreased valve angle, allowing for higher lift cams, increased PTV clearance, or ability to run larger valves. Additionally, reshaped lower volume intake ports (higher velocity), and much less restrictive exhaust ports. In higher boosted applications there are aftermarket heads with thicker decks for a better clamping surface/stronger casting or also for more metal to work with if surfacing/milling is needed to achieve a certain deck height or compression ratio.
If I had boatloads of money I would love a set of Mast Black Labels or FED's. But I don't and will likely be fine running with a set of ported stockers, GMPP, GPI, or maybe even mid level type head like PRCs or similar. From what I have seen on cammed NA 6.2s, you could expect maybe 20-30+hp on ported stock heads and upwards of 40 hp+ on certain aftermarket castings. Obviously, there are tons of variables to consider though.
10-11-2020, 06:02 PM | #12 | |
They are pretty impressive. |
10-12-2020, 08:09 AM | #13 |
Drives: 2010 Black 2ss Camaro SS Join Date: May 2010
if you are set up for e85....why ever run anything else?
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
10-12-2020, 08:49 AM | #14 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Stick to either the AFR or TFS aftermarket heads for the LS3. Any ported head will gain hp up top but you may also sacrifice low end. Milling to increase compression helps gain back the low end but you could have more PTV if you mill too far which will require fly cutting the pistons
With the two above castings you get an intake port that’s the same size as stock but with a ton more velocity which will help with power/torque gains. The improved valve angle will allow more compression before getting into PTV as well. Give Tony Mamo a shout if you’re really serious about adding heads. He will steer you in the correct direction for your build
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 Last edited by xc_SS/RS; 10-12-2020 at 09:15 AM. |
