Old 04-13-2018, 12:01 AM   #1
The_DarkKnight
Drives: 2018 ZL1 1LE
first oil change, what do I tell them about lift?
how do I keep them from damaging the underside, where should they lift, I think Im buying the ZL1 add on pads, but is there a safe place they can lift without them? sorry if this is kind close to same topic of my last thread
The_DarkKnight is offline   Reply With Quote
Old 04-13-2018, 12:26 AM   #2
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Do it yourself or RIP.
ninetres is offline   Reply With Quote
Old 04-13-2018, 01:05 AM   #3
waterman
waterman's Avatar
Drives: Grandad's C2 L89
+1
Generally, the most inexperienced kid in the shop does the oil changes.
Feeling lucky?
2018 ZL1 1LE sw/PDR
Old 04-13-2018, 05:35 AM   #4
Gabhart
Gabhart's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Agree! Do it yourself. May be inconvenient to some but well worth not to have to worry about damage. Invest in some ramps at a minimum.
Gabhart is offline   Reply With Quote
Old 04-13-2018, 06:09 AM   #5
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Maybe you will get lucky like me. My dealership has a separate building for oil changes and light maintenance. It has the pit you drive over just like the quick oil change places. No lifting! But since you are in Mogadishu - I'm not sure what you'll find at your dealership. Ha!
476 rwhp/440 rwtq (sold)
Old 04-17-2018, 07:03 AM   #6
The_DarkKnight
Im looking for maybe a diagram to show them where to lift and where not too
Old 04-17-2018, 08:22 AM   #7
rjacobs
Drives: none
With a post lift with arms they should be able to take the lift pads off and just have the large pins. These pins will go in the 4 holes under the car where its designed to take said load if lifted all 4 at once. Thats the most ideal way to do a post type lift.
rjacobs is offline   Reply With Quote
Old 04-17-2018, 08:50 AM   #8
IneedAZ
IneedAZ's Avatar
i told the dealer to use a drive up lift and they did
Old 04-17-2018, 09:05 AM   #9
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Here is where to lift with the four point or the pinch weld.
But the best way is in the 3rd picture.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 04-17-2018, 09:23 AM   #10
bigtexhand
bigtexhand's Avatar
Drives: 2017 Garnet Red 2SS
I've always chosen to do my own minor maintenance as long as I'm capable of doing it safely and economically. This is my first Camaro so I'm still on the learn-as-I-go path, but are GM dealerships and mechanics REALLY unable to safely lift a car that they manufacture tens of thousands of? I'm not doubting anyone on this forum that have had their cars damaged by some kid waxing cars and doing oil changes for the summer but it worries me to think that I can't trust a certified mechanic that's spent countless hours under these cars.
bigtexhand is offline   Reply With Quote
Old 04-17-2018, 10:07 AM   #11
unavailablezl1
Where did you get your Race Ramps? Those are the ones I am thinking of getting. I like the idea of two piece
Current ride
Past Rides
Old 04-17-2018, 10:27 AM   #12
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
It's a bit over stretched, you have some people that just don't trust anybody no matter what and go around saying to do everything yourself or they'd do the work better than anybody. Now there is truth to nobody is going to care more about your car than you will. However, if you have a good dealership, talk with the service manager and stress that this car is very important to you and you don't want an inexperienced tech to do it and you would prefer a drive on lift, and say you'd also like to watch, then you should be golden. They should comply with all of the above without any back and forth. Just drive it into the service drive, let them put plastic on the seat and floor and then follow it to the service center and watch them. It would definitely help if you knew how to do the oil change on these cars so you could see if they're doing something wrong. Lifting up by a 4 point lift isn't too bad, most techs should know how to do that. Drive on is preferable though as sometimes techs just get rolling and don't like to go slow and pay attention. But techs also know that whatever they screw up is going to cost them big time, so because of that they tend to take care even if you don't think they are.
OP, there's diagrams out there but they only instruct to lift the car by the pinch welds and unless you bring the ZL1 addons jack pads or similar, then they're not going to be able to lift by the pinch welds. Either request a drive on lift, or make sure they know the lift points that are safe with a 4 point lift.
Old 04-17-2018, 02:59 PM   #13
init4fun
Drives: 2017 50th Anniversary
Find a dealer that specializes in Corvettes and Camaros. There is one dealer local here that knows what they are doing. The other 5 have no flippin clue. When I dropped mine off I asked to talk to the guy doing my oil change before hand.
I asked him if he knew how to pick up a Camaro and he slide under the car and pointed at the lift points. I felt ok about it after that.
init4fun is offline   Reply With Quote
Old 04-17-2018, 06:28 PM   #14
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I love the ZL1 but the underside and unibody is no different than a rental company SS or LT. Any dealer can lift a Camaro adequately unless the car wash boy puts it on a lift for his inaugural procedure.
