01-09-2017, 12:58 PM | #15 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Regardless, if I was doing a brake fluid upgrade, I would not bother with GM stuff, Motul is all I would use. |
01-09-2017, 02:48 PM | #16 |
Drives: 2017 Camaro SS Join Date: Aug 2016
I use RBF600.
There's only one brake fluid in the manual and it's definitely the part number for a DOT3 fluid. I wasn't recommending anyone actually use that though. Checking my oil this morning I notice the fluid cap even has DOT3 stamped on it. Last edited by AndyUK; 01-10-2017 at 08:24 AM. |
01-25-2017, 06:09 PM | #17 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
OK- now that temps have dropped, I'm really disappointed with manual shifting on my SS 6spd.
Whats the the fix? Replace the factory fluid or change to AMSoil or what? I was initially impressed with stock shifting when I got my 2017 in warm weather, but now it's not so great. Any suggestions? Thanks in advance! |
01-25-2017, 11:08 PM | #18 | |
Drives: 2016 Camaro SS 6 speed manual Join Date: Dec 2016
01-26-2017, 10:02 AM | #19 | |
Drives: 2016 1ss camaro Join Date: Dec 2015
01-27-2017, 06:36 PM | #20 | |
I've used AMSoil before but had best results from the RP (even tough I thought it must be a gimmick- the stuff worked!) Thanks again! Also- I thought they all (SS's), had coolers. So what is the capacity? |
01-27-2017, 09:27 PM | #21 |
Www.royalpurple.com should be able to tell ya everything you need to know. I believe it's 5.2 qts for the tyranny with cooler.
01-28-2017, 10:42 AM | #22 | |
Poppycock
Drives: Pontiac GTO Join Date: Dec 2013
01-29-2017, 05:39 PM | #23 | |
Looks like Royal Purple Synchromax is my next move... thanks again for your info, it's pretty hard to come by around here! |
01-29-2017, 05:51 PM | #24 |
No I didn't remove anything, but the fill plug and then the drain plug. Fill plug first so it wouldn't splash when the drain plug was removed. I used an extension for my ratchet and went over the top of that line that runs kind of in the way.
02-04-2017, 12:07 AM | #25 |
Drives: 17 HBM 1LE Join Date: May 2016
where under the car did you find the drain and fill plugs
02-04-2017, 10:46 AM | #26 |
It's on the drivers side of the transmission. Drain plug is also the heat sensor for the transmission so it has a wire with a quick disconnect on it. The fill plug is directly above the drain plug. I believe the fill plug is a 3/8 ratchet to remove it. Just the ratchet no socket.
02-04-2017, 10:53 AM | #27 | |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
02-08-2017, 12:20 AM | #28 |
page 347 of the owners manual states the part# for manual transmission fluid is 88861800 and not dot 3 brake fluid?
