Old 11-28-2016, 06:30 PM   #1
Sooks569
2016 Oil Change
I might be attempting an oil change myself next time (if not this time then definitely the next time after that). Is there a crushable washer underneath the Drain Plug that needs to replaced in addition to the oil and filter replacement? If so, does anyone have the GM part number? I see a mention of a "seal" and an "Insert" on the parts diagram.
Sooks569 is offline   Reply With Quote
Old 11-28-2016, 06:40 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
You can use that washer again.....
Old 11-28-2016, 07:16 PM   #3
c4racer
Drives: 2016 SS Convertible
You could but I would change it. It crushes pretty good. It's a rubber seal. My local parts store had them for less than half what the dealer charged. Almost pissed myself when the parts guy told me they cost $6. Almost what the filter costs !!!
c4racer is offline   Reply With Quote
Old 11-28-2016, 10:11 PM   #4
TJay74
It is a not a crush washer per say, GM has used the same style oil pan drain bolts for decades now. It isn't a revolutionary thing. If it isn't leaking re-use the current one, if it is showing signs of weeping then replace it.
Old 11-28-2016, 10:23 PM   #5
Sooks569
My last two cars were Nissan Altimas, they used copper crushable washers. I had a couple Oldsmobiles and a couple Pontiacs after that. I don't remember having a washer/seal under those plugs then. Is there any kind of links so I can see what I need?
Old 11-28-2016, 10:25 PM   #6
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Correct… ....… It's a std washer, if you want to get rid of it forever, put in a stahlbus valve.....Google it.
Old 11-28-2016, 10:30 PM   #7
ELS1
Drives: N/A
It's not a copper crush washer like the nissans (I have a g35), those are recommended to be changed out each time. GM however uses a rubber gasket on the drain plug like https://www.amazon.com/Needa-Parts-6.../dp/B001NYP6VU
Modded 99 Z28 - Gone
ELS1 is offline   Reply With Quote
Old 11-28-2016, 10:37 PM   #8
Sooks569
So it's like a packing! I found the seal, they're about $3 each. http://www.gmpartsdirect.com/oe-gm/12616850
Old 11-29-2016, 01:00 AM   #9
c4racer
part $3, shipping $11.95
Old 11-29-2016, 01:38 AM   #10
TenSeven
Drives: 2016 Camaro SS
Hahahhahaha... Good old GMPartsDirect and their shipping:
"Estimated Shipping to Huntington Beach, CA: $13.51"
TenSeven is offline   Reply With Quote
Old 11-29-2016, 01:39 AM   #11
TenSeven
Originally Posted by Glen e View Post
...put in a stahlbus valve.....Google it.
I did Google it, ingenious device. But for the $55 price I think I'll stick to a wrench.
For now...
Old 11-29-2016, 06:51 AM   #12
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
They use the same drain plug as the Silverado, Camaro, Ecotec, LGX, they use it in A LOT of engines. 30,000 miles on my truck, oil changed every 3k miles, never changed the O-Ring that's on it (its just an O-Ring and a nice one at that). Has never leaked. I wouldn't bother changing it unless it does. BTW...if you really must change it, buy the whole drain plug (comes with the seal) as it is only $0.40 more than the seal itself.
As a bit of reassurance for you, from the GM service manual:
Note: Clean and inspect the oil pan drain plug seal (2), replace parts as necessary.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
Originally Posted by fbodfather View Post
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 11-29-2016, 07:06 AM   #13
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
For now...
Until you cross thread the bolt and put carcenogenic oil on the floor....
We are all different, $55 is nothing for me, I spill more on the floor mixing drinks than that…
