Old 11-29-2021, 11:16 PM   #15
95 imp
Dumb Ass Deluxe
Originally Posted by BlackbeastSS2 View Post
Making your own E85 when it’s not available or close by.
I ordered a 30 gallon drum of E85 today because my area does not have any E85 close by. The nearest Speedway Gas Station is 2 hours 11 mins away.
So other then filling up my 5 gallon jugs for track runs has anyone thought or maybe has already looked into making their own E85. I have started to explore this but would like some input on this topic.
More money and time than it's worth to distill your own.
Plus, if you start making a lot, the BATFE will probably visit you. Especially if you sell it.
Old 11-30-2021, 07:59 AM   #16
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I've tried running E65 thru E85 and found no performance gains on the dyno or at the track above the E65 level. My VP dealer who also has a VP station has his own blend of what I would call true E85 with a blend of X98 and 93 octane. I do buy that for racing only and its not much more expensive then what I buy at my local flex fuel station which is usually only between E65 and E70.
Old 11-30-2021, 07:27 PM   #17
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
That doesn't make a lick of sense. The L9H is 10.5:1 compression...it shouldn't knock on any amount of E or something is off in the flex tune. It's adding too much spark for the amount of E content or something. Especially if it doesn't knock on 93 pump gas. E40 is still 100 octane.
Yeah I was surprised as well. I've tried it with the stock tune and my own timing maps and LS3 maps and everything else. I haven't really experimented that much with just straight 93 but I know it knocks just as bad even with 89. I can also hear the knock everytime I see it on the scanner, and I can also hear it and for some reason it won't show up on the scanner. Both sensors are new also, and knock count between cylinders looks consistent and relatively even also.
But once I hit about 50% it 100% vanishes.
I haven't done that much experimenting with blends on my LT1 but so far it seems the same way, it takes about 50% before much effect on knock resistance (or at least knock sensor triggering).
cmitchell17 is offline   Reply With Quote
Old 12-06-2021, 01:30 PM   #18
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
The MicroFueler sells for $9,995 and requires a deposit at the time of order. E-Fuel is able to ship units to anywhere in the United States, China, India, Australia, Europe and Brazil.
$200 per month on E X 12 months $2400.00
tax credit?
4 years to pay for it self and sell some along the way..
Old 12-06-2021, 03:29 PM   #19
Trochoidal
Drives: 2017 Camaro 2SS A8
tax credit?
Who knew there was a “turn key” solution?
Old 12-13-2021, 07:28 AM   #20
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Well I cracked open the barrel and put 5 gallons of E85 in the tank, might have been 1/8 of a tank left of 93 pump in it. I had just finished installing the E85 gauge and ran the car, it was at 55%. The car seemed to love it, it was either the colder temps, E85, or the ECU finally fixed my idle drop/surge when I would come to a stop. It ran like a champ on E85. Now just need to upgrade the injectors and high side pump over the winter months, then in the spring slap on the Procharger with axle/driveshaft. So looking forward to this spring.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
