11-27-2021, 09:15 PM | #1 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Magnetic Car Numbers
Alot of your track events especially the time trial events require that your car has numbers on BOTH sides of the car. Below is a pics of a set of magnetic numbers that I had FAST SIGNS make up for me.
I usually run NUMBER 24 BUT in case I go to an event where that number is already taken, I had them make up a additional single digit number (1 in my case) so that I can place it IN FRONT of the 24 to get car number 124 or in back so that I can run 241. I ALSO had then make up a THIRD number (not pictured) that I can run it on my trunk (it is NOT slanted) and another number "1" to with it. The numbers are EIGHT inches high and the entire set will cost you about 180 dollars with design and all. BTW the shoes are mine also in the bottom of the pic and you can see the front paw of my dog also LOL
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
