Old 11-22-2021, 08:34 AM   #1
TheeMajorBone
TheeMajorBone's Avatar
Drives: 2020 Cadillac CT5 Sport
Are my tires incorrectly installed?
This doesn't look right to me. The tires should have a lip that protrudes slightly past the rim. What do you think?
Correct install or no?
2020 Cadillac CT5 Sport Summit White / Jet Black
2018 Camaro 2SS Hyper Blue
2014 Chevy SS White
2014 Silverado High Country
2008 Pontiac G8 GT - White Axel Back Solo / Volant CAI
TheeMajorBone is offline   Reply With Quote
Old 11-22-2021, 09:08 AM   #2
Dabjbr
Drives: 2020 SS 1LE
Did you mean to attach a pic? I see nothing.
Also, it should have nothing to do with the installation. The bigger questions are size of rim? Size of tire?
Lastly, keep in mind some tire manufacturers have square and some have more rounded shoulders.
Dabjbr is offline   Reply With Quote
Old 11-22-2021, 09:21 AM   #3
ctrlz
Tires will either have direction of rotation labeled somewhere, or have inside and outside labeled. Not all tires will have the rim protector, which is the bulge you are describing.
Post the exact model of tire you installed.
from what I see about Pirelli p-zero, it will depend on the year and model of tire if it has a rim guard.
Old 11-22-2021, 10:07 AM   #4
TheeMajorBone
my brother had a set of the exact same tires on his mustang, obviously different rims, but the rim protector stuck out more. Couple years ago and different rims are enough for the variance I suppose. Thanks for the advice!
2014 Chevy SS White
Old 11-22-2021, 12:04 PM   #5
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Too little info to say anything...wheel size, tire size, etc etc solely by the picture I'd look in to it further. Tech's do mismount tires, inside/outside, left/right, backwards from the rotation indicator, and so forth. I always stop and look at mine when I change out to ensure these things.
WhiteMale is online now   Reply With Quote
Old 11-22-2021, 01:56 PM   #6
Aquarius
Aquarius's Avatar
Drives: Rapid Blue 2022 Camaro 1SS
Not a tire expert, but I will say it looks like the bead did not mount flush to the edge of the wheel. I can not ever remember seeing a tire have such a gap between the edge of the rim and the tire bead. Just curious: is the tire made to fit on the wheel size you have? From the angle of the picture, it looks like you already have the walls of the tire flexing out.
9/9/2021 - 1100 (date of deposit)
10/15/2021 - 2000
11/4/2021 - 3100 Status TPW 11/15
11/9/2021 - 3400 Status TPW 11/15
11/24/2021 - 3800 Status built 11/21/2021
12/2/2021 - 5000 Status
12/13/2021 - 6000 Status
Aquarius is offline   Reply With Quote
Old 11-22-2021, 02:39 PM   #7
WhiteMale
Actually looks like the tire is stretched or undersized to the rim, too.
Old 11-22-2021, 02:54 PM   #8
I see the same as Aquarius, the bead looks only half seated, look at my Michelins for comparison.
Then again, you run Pirellis that might have a very different bead profile, plus we don't know the tire size and which wheel your picture shows, front or rear; please post all this info.
Old 11-22-2021, 05:27 PM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Tire is narrow for the wheel is all. Some brands of tires will run narrow for their size rating. Nitto use to be notorious for that.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 11-24-2021, 02:41 PM   #10
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
That doesn't look right. I'd take it to another tire shop and ask someone with experience.
What size tires and wheels, including the width?
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
