Old 09-18-2021, 08:13 AM   #1
MVPxD
MVPxD's Avatar
Drives: 2021 Camaro LT1
ZL1 door panels in LT1
I have ZL1 door panels I plan to install on my 2021 Camaro LT1.
I spend quite a bit on the panels so I do not want to spend another $650 on the spectrum kit to program the rgb lighting. However, given that the panels already come with the lighting, is there a way I can at least provide power to the lights so just have them on even if I don’t have the ability to change colors.
Anyone know where I can plug them in to provide power? A diagram and instructions would help as I’ve never done something like this.
Also anyone have instructions on how to swap harnesses on the panel? I heard if I just do a straight swap the mirror controls or something won’t work?
Thank you.
MVPxD is offline   Reply With Quote
Old 09-18-2021, 07:45 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I don’t believe anyone for the OEM lights to work unless it was added/programmed by the dealer
As for the harness swap IIRC you unplug everything and push it through the main harness hole. I don’t believe you can fit the big body/door connector so go the other way and push the wires through that hole
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
