Old 09-06-2021, 06:30 PM   #1
Beescuz
Beescuz's Avatar
Drives: 2021 ZL1 1LE
Rear Axle System Off
So on Saturday I was tracking the car at Daytona 24hr Config course. Half way thru the day "Rear Axle System Off" message came up. The message only came up one time both days while tracking it, but while driving it back and forth to the gas station in tour mode the slip indicator light was continuously flashing. If I went into another mode it wouldn't flash. I was running the car on the track in track mode/race setting. Dropped it off at the dealer tonight so will see what they say this week. Thoughts what it could be?
Beescuz is offline   Reply With Quote
Old 09-07-2021, 01:20 AM   #2
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
Following
Old 09-07-2021, 09:20 AM   #3
Beescuz
Beescuz's Avatar
Update
Update from dealer:
Limited slip fluid leaked into the rear differential. They are installing a new rear differential. Should be in tomorrow.
Old 09-07-2021, 12:53 PM   #4
NickyRacerBoy
Drives: 1LE
Originally Posted by Beescuz View Post
Update from dealer:
shit....wow
NickyRacerBoy is offline   Reply With Quote
Old 09-07-2021, 06:15 PM   #5
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
Help me understand what that means. The way I understand it differential fluid is supposed to be inside the differential. Did it flow into the ECU which controls the engagement of the clutch pacts on the eDiff? Or are the clutch packs separate, and the diff fluid leaked into the diff from the clutch packs?
5.M0NSTER is offline   Reply With Quote
Old 09-07-2021, 07:00 PM   #6
Beescuz
Beescuz's Avatar
The EDiff fluid leaked into the differential. They checked the fluid level of the EDiff and it was low. Then they checked the fluid level in the differential and it was high. When they drained the differential they could see the mix of fluid. They are saying currently that they believe a seal went between the two which caused the issue.
Old 09-09-2021, 06:34 PM   #7
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
The clutch packs, all gears, and the carrier are all in regular diff fluid like any other LSD. The hydraulic fluid that controls the amount of clutch pressure and the pump for that is totally separate and the fluid is very different. So they're telling the OP that the hydraulic fluid leaked into the main diff housing and mixed with the diff oil.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 09-09-2021, 07:25 PM   #8
5.M0NSTER
5.M0NSTER's Avatar
That makes sense now. Thanks guys.
OP, good luck getting the issue resolved.
Old 12-01-2021, 06:30 AM   #9
Lewisracing
Lewisracing's Avatar
Drives: 2018 1SS 1LE Hyper Blue Metallic
Random thing for this, regarding GM.
I was at Daytona in mid-September for racing and had the same issue, but it was software related. Something to do with the G forces on the banking that can freak out the system at very slow speeds(~30mph for me) and even at transition off the banking at high speeds.
I spoke to GM about this and they were able to replicate the problem while testing, they are working on an update for this incase anyone runs into this issue but it's not actually the diff like in your case.
@Lewisracing1018
Instagram: Lewisracing1018
YouTube: https://www.youtube.com/@JLewisRacing927
NASA ST/TT3 #927
My build thread: https://www.camaro6.com/forums/showthread.php?t=620013
Lewisracing is offline   Reply With Quote
Old 12-02-2021, 04:38 PM   #10
Beescuz
Beescuz's Avatar
So how do we get the software updated in our cars once GM updates it?
Old 12-02-2021, 04:51 PM   #11
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
Must be a new problem. I've run Daytona a dozen times in my 2017 1LE and never had an issue.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 12-02-2021, 07:49 PM   #12
HD_ZLE
HD_ZLE's Avatar
Drives: 2020 ZLE
following. This is a rather interesting one
2020 ZLE A10
Rotofab, SPL suspension goods, Cobalt XR1 pads, Apex wheels
HD_ZLE is offline   Reply With Quote
Old 12-03-2021, 08:29 PM   #13
Kmeleon
Drives: 2018 NFG 2SS 1LE!
Ediff fluid? Is this something we should be checking? Never knew there was separate fluid from the differential.
Kmeleon is offline   Reply With Quote
Old 12-05-2021, 03:17 PM   #14
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
sub'd, this is interesting, OP never heard of a leak there
Kmeleon: on the back of the cradle near the diff housing there is an aluminum "square" with electrical connectors on the driver's side and hoses on the passenger side. this is the electro/hydraulic system that changes the bias of the differential on the fly per system programing.
I've been told the fluid is Dexron IV (transmission fluid) and doesn't have a maintenance interval. There is a procedure for refilling it, but only in the case of a needed repair.
