04-05-2021, 03:08 PM | #1 |
Drives: 2019 Camaro SS 1LE Join Date: Oct 2020
Pray ported IM for sale, fits 95mm TB $285 shipped
Pray ported LT1 Intake Manifold. NOTE- PRICE DROP $225 Shipped
I bought this from a member here. I decided to stick with a ported 87 mm TB so I do not need this IM. As I had intended to use it, I cleaned it up (not that it was dirty - looks barley used), installed new OE GM gaskets/'D' rings and Heat Shield products shielding. Shipping for continental US only Last edited by BobT; 05-13-2021 at 07:47 AM. Reason: price change |
04-06-2021, 12:27 AM | #2 |
Drives: 2016 Chevy Camaro SS Join Date: Mar 2020
This is an LT1?
04-07-2021, 04:10 PM | #3 |
ALL the boost
Drives: 2019 Camaro 2SS A10 Join Date: Nov 2014
PM sent
2019 Camaro 2SS A10 // ECS Novi Centri // Speed engineering 2" primary longtubes // 3" straight pipe collectors back // LT4 fuel system // Airlift performance 3P/3H
2010 Camaro 2SS 6MT // Cat delete // Muffler delete // resonator delete // Turbonetics kit // BC Coilovers // BMR Trailing arms // BMR toe rods // BMR bushings whole rear // LPW diff cover // FIC 1000cc injectors // ZL1 Fuel pump--646whp / 670wtq @ 8psi--Sold |
12-02-2021, 09:45 AM | #4 |
Bump
Pray ported LT1 IM, lightly used and clean, with throat opening ported out to 95mm This eliminates the O-ring interface so one must use some RTV This is still available but I am keeping the new D-rings. Has hold down bolts but 1 is missing $195 shipped mainland US only |
