09-29-2021, 01:10 PM | #323 | ||
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
For reference, here's an example of me spinning on track in PTM Race due to trying to apply throttle earlier when exiting this corner than on previous laps then lifting after oversteer starts and getting on the brakes. I probably could have caught the slide without overcorrecting if I had maintained about the same amount of throttle during the oversteer or decreased it just slightly instead of lifting: https://youtu.be/RV_zyaz9ORg And here's someone spinning in PTM Race where you can see the traction control light never blinks because the oversteer happened while the driver was trail braking: https://youtu.be/quW3wA88f-c&t=45s Here is an example of someone else spinning on track in PTM Sport 2: https://youtu.be/Qo6I0KkQmv4&t=1m8s It may be possible to spin with all 4 wheels on pavement in PTM Sport 1 too but probably less likely. This person spun in Sport 1 but it looks like it was caused by dropping a wheel partly into the grass on corner exit: https://youtu.be/WagmKKz3UwY&t=10m42s There's also an autocross calibration available to buy for the eDiff that the dealership can flash onto your car but I believe it kicks you out of B street class and into CAM-C in SCCA autocross. https://www.camaro6.com/forums/showthread.php?t=579951 https://www.camaro6.com/forums/showthread.php?t=549151 https://www.camaro6.com/forums/showthread.php?t=532096 Last edited by cdrptrks; 09-29-2021 at 03:21 PM. |
09-29-2021, 01:15 PM | #324 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
I think if you're used to driving with all systems off (my background) even PTM race is easy to manage. I do have to throw in 100+ degrees of counter steer every so often, but I can stay on the throttle and just manage the side slip with steering.
I like PTM race, doesn't neuter the car much at all. I am a bit faster in PTM race than in Sport 2. Fractions of a second, but still. |
09-29-2021, 02:24 PM | #325 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
09-29-2021, 02:43 PM | #326 |
Good tip about going full off. I haven't tried that yet in this car. Only 2 track days in the dry so far. Good goal for next season!
09-29-2021, 03:28 PM | #327 |
What I have found all year with all the testing to see what I like. Always variations but basically what I have found. Cooler temps in morning all off in sport is pretty controlled, but in the heat the car is more loose and slower in nannies off. That’s with a low grip surface.
09-29-2021, 05:51 PM | #328 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Matt Miller
2020 SS 1LE |
10-09-2021, 06:38 PM | #329 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
05-09-2022, 07:31 PM | #330 | |
Drives: 2022 ZL1 1LE Join Date: Feb 2022
Is there anyway to confirm which mode you're in (Wet/dry/S1/S2/R)?
Every time I select a drive mode and then go back in, it's back at WET. I just want to be sure I'm in the right mode. Also, does this sound right? every time you press the ESC button it goes back to WET? Thank you to anyone who can answer. Quote:
05-09-2022, 09:15 PM | #331 | |
Hope this helps. |
05-10-2022, 01:49 AM | #332 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
To lock in the right mode, simply use the mode up/down button on the center console. There is no need to press the SEL button on the right side of the steering wheel to enter it. If I recall correctly this has been discussed earlier in this thread.
Mosaic black 2018 Camaro 2SS A8 (sold) |
05-10-2022, 04:12 PM | #333 |
Drives: 2021 2SS 1LE Join Date: Aug 2020
My experience is that once you are in PTM mode, you change modes (wet,dry,S1,S2,Race) by just pressing up or down on the mode select button on the center console. As MakCamaro says, no need to press the select button on the steering wheel.
The DIC will show which PTM mode you are choosing by highlighting your selected mode in in the stacked list. However, once the mode is selected, the PTM display disappears in the DIC. To get it back again, just press up or down on the mode select button on the center console. And NO, it isn't normal for it to jump to WET each time you toggle 1 up or 1 down from your previous PTM mode (unless of course you were in RACE and then toggle down on the mode select button). |
05-10-2022, 04:42 PM | #334 | |
The first time was VIR turn 3, where the induced rotation was beautifully slow and the ECS intervened to catch the rear (successfully) right as I was about to add some counter steer. If I hadn't mentally paused to admire the rotation I had induced, I probably could have added some throttle while opening the wheel to settle the rear and the ECS may not have even intervened. The second time was at VIR turn 4, where the induced rotation was much faster. This was under aggressive trail braking (where I recorded 1.5 lateral G while still having some longitudonal G from slowing the car). The ECS started trying to catch the rear about 1/4 second before I added opposite steering lock. I overcorrected slightly, but without the countersteer, I do not believe the ECS would have successfully caught the rear, as the yaw rate was quite high. Word to the wise: When you start practicing and playing with trail braking, be prepared for oversteer and do not assume that ECS will save you, even in PTM Sport 1. |
05-10-2022, 06:03 PM | #335 | ||
It starts around the 4 minute 32 second mark. |
05-10-2022, 07:18 PM | #336 | |
When you pick a PTM choice, the latter lights up on the display and stays there until you turn the iginition off, or push one of the button which toggles between PTM choices. So, I suspect, you somehow manage to drop the car in PTM Wet, by pressing the button. Hope this helps. Cheers! |
