08-01-2022, 11:37 AM | #1 |
Drives: 2022 Camaro 1SS 1LE Join Date: Nov 2021
Which eLSD fluid? 2022 1LE M6
Which eLSD fluid should I be using on my 2022 1LE M6?
I read the sticky thread, but didn't see much references on which current fluid to go with. From my research I am reading about the following: Amsoil Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid - ATLPK-EA Or AC Delco - but which fluid? 10-4034? And what about a friction modifier - which part number?
2022 Camaro 1SS 1LE 6-speed
08-01-2022, 11:50 AM | #2 |
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
Use the stock diff fluid, it’s got the friction stuff in it already. The electric part of the diff takes a different fluid and shouldn’t need to be changed.
08-01-2022, 11:51 AM | #3 |
Which part number for the stock fluid do you go with?
08-01-2022, 12:02 PM | #4 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
10-4034 is correct
08-01-2022, 12:50 PM | #5 |
Thanks All, will use 2 quarts of 10-4034 with a hand pump.
When jacking up the car, does it need to be even? Do you guys lift the rear by the rear differential? Can I jack up the rear only?
08-01-2022, 01:43 PM | #6 |
Shadow Gray '19 ZLE M6
You'll want the car level, especially for filling.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
