09-29-2010, 09:04 AM | #29 |
Drives: 2010 Hendrick Modified SS #015 Join Date: Sep 2010
I have the Hurst on my car too. I am not new to Manual transmissions, and it wasn't skip shift. I was at about 5500 rpm when it happened and the clutch was on the floor when I pulled the shifter to 2nd gear. The grind happened before I let my foot off the clutch. Then the next day the clutch pedal got stuck half travel....WTF. Had to pull the pedal back to the "home" position. Kinda weird.
09-29-2010, 09:13 AM | #30 |
Never experienced this with the stock shifter or my Hurst. It could be she's letting up on the clutch a little to early or there could be a problem with the clutch pedal sticking? Some people have reported that. Has she noticed that at all?
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
09-29-2010, 09:30 AM | #31 |
Drives: 2010 ss/rs black w/ cyber gray stri Join Date: Mar 2010
Its not her I have had that problem since new. I actually blew 2nd they fixed it and it still does it under hard driving !!!!!!!!!!
09-29-2010, 05:50 PM | #32 |
Drives: 2SS-RS Join Date: May 2010
Could it be just the shifter hanging up a bit going from 1st to 2nd?
Check fluids to ensure they are topped off and that the clutch is fully disengaging. |
09-29-2010, 06:09 PM | #33 |
Drives: 2010 White/IOM 2SS/RS M6 Join Date: Jul 2010
I experienced this problem twice. The first time was at the track. I was sure that my timing was right but convinced myself it was my fault after it didn't happen again that night. Just the other day after I got my headers and stuff on it did it again. I know my timing was right. I thought these transmissions were stronger than that?
2010 White/IOM Camaro 2SS/RS M6
09-29-2010, 07:30 PM | #34 | |
Arizona All Gens
Drives: 2SS/RS, M6, IO-Int Join Date: Jul 2007
10-06-2010, 12:54 AM | #35 | |
Camaro SS Lover
Drives: 2010 Camaro 2SS/RS Black IOM Join Date: Jun 2010
I've done numerous suspension upgrades, including a chassis brace, and believe me this issue is not caused from jolting of the tranny or gears. It's either a mechanical issue with the syncro or need to press the clutch to the floor at high RPM's.
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
10-06-2010, 02:33 AM | #36 |
Drives: 2011 2SS IBM, 2008 Victory Vision Join Date: Apr 2010
I have a similar issue; been driving manual for 15 years in various sports cars so I doubt it's operator error. I find that when the car is cold, when at low speeds, with my foot pushing the clutch to the floor I get a gear grind going from 1-2. I've been working ridiculous amounts lately so I haven't gotten to go back to the dealer with it yet. 900 miles on car.
10-06-2010, 02:40 AM | #37 | |
Drives: 2011 GT500 Join Date: Jun 2008
i've experienced it myself but being that i've owned a 2ss m6 last year and now the gt500 i can say in my opinion it's all about the engage/disengagement of the shift. alot of people softly shift from first to second, when shifting at a higher load you need to man handle the move from 1 to 2. if you dont, your foot will naturally start to slip back the clutch and you'll find yourself grinding. this was kind of apperant on the 2ss m6 i used to have and even more so the gt500's... the main difference? the shorter throw found in the shelby. makes sense, i had the issue happen once or twice on high load in the 2ss m6 over the year that i owned it and it happened 5-6 times in the first 2 months i've owned the gt500... now that i put more force in the shift, it's gone away. (and by force i mean stern force, not voilent... dont go smashing your gear selector) |
10-06-2010, 07:34 AM | #38 |
Irreverent Schmoe
Drives: Black 2010 2SS Join Date: Apr 2010
I get a little gear grind from 2nd to 3rd sometimes but only when it is cold and I am not getting on it hard...
Black 2SS,M6,Sunroof,R6P.11390
Tags |
hurst, second grind |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
1st and 2nd gear problems. 1SS 6M | jnm2003 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 7 | 10-29-2019 12:22 PM |
Starcraft II | Brokinarrow | Off-topic Discussions | 57 | 08-17-2010 12:51 PM |
2nd Annual Surf City Garage Car Show 08/22/10 | So Cal Camaro | California Meets and Events | 0 | 08-05-2010 12:08 AM |
grinding while shifting into 2nd gear (LS3) | rcracer78 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 46 | 02-13-2010 12:10 AM |
YIKES !!! GRINDING FROM 2ND TO 3RD ! any thoughts ?? | billyspeed | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 6 | 01-14-2010 08:39 PM |
