07-07-2020, 11:11 PM | #1 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
2010 RS front suspension
Just picked up a 10 v6 as a DD. 44k miles, all is great except 1. still original tires and feeling out of balance through the steering wheel slight shimmy at high speeds (but not my issue here), and 2. I hear a slight thud from the left front at low speeds when driving over cracks in the asphalt or expansion joints.
No visible sturt/shock leaks, nothing seems out of place. Any ideas? Thanks
"Make yourself sheep and the wolves will eat you"
07-08-2020, 05:08 AM | #2 |
1. LCAs, inner tie-rods or tie-rod ends, or out of balance tires, or cupped worn tires.
2. End links or sway-bar bushings. |
07-08-2020, 09:23 AM | #3 |
Thank you. I’m convinced issue 1 is tire related, so not overly concerned. But will check end links and bushings for issue 2.
07-09-2020, 08:39 PM | #4 |
Visually, the end links looked great, but for $50, I ordered both sides today. Easy job, worth swapping. It’s a 10yr old car
07-13-2020, 04:00 PM | #5 |
Thanks CamaroDude. New end links killed the suspension noise issue (I also tightened the 13mils bushing brackets) and the 2018 SS wheels/tires I picked up yesterday fixed issue 1. Drives like a new car again
07-13-2020, 05:26 PM | #6 |
I installed Whiteline bushing inserts in the front forward LCAs. Tightens up even
more. https://postimg.cc/gallery/GT1M9M1 |
