View Poll Results: Who has experienced an oil pump failure? | |||
2016 or earlier | 20 | 13.79% | |
2017 | 53 | 36.55% | |
2018 | 67 | 46.21% | |
2019 | 2 | 1.38% | |
2020 | 2 | 1.38% | |
2021 | 1 | 0.69% | |
Voters: 145. You may not vote on this poll |
Thread Tools |
02-22-2020, 10:20 PM | #295 |
Drives: 2018 Camaro ZL1 Summit White Join Date: Apr 2018
Mark me down as another oil pump victim. 24k miles. 2018 ZL1. Build date 11/2017
Running fine. Drove home. Parked. Came back to head out for dinner, fired it up waiting to warm up and BAM now oil pressure message turn off engine. Shut off engine and immediately checked oil dipstick, no flakes or glitter. Engine was actually running quite smooth given the low oil pressure. Gonna get a local guy here get his hands into it vs sending it down to the lower 48 to get a dealership to possibly not even work on it. I did make a post a few months ago about my oil psi at hot idle being 20psi. So friends. If you notice your oil pressure at hot idle hovering in the 20psi range. That's your first sign! Any other oil pump failure out there who just replaced pump and went on their way? I know when the engines torn apart to look for signs of oil starvation, but I think thankfully since I shut it off and it was at idle I should be okay. |
02-23-2020, 10:52 AM | #296 | |
Drives: 2018 ZL1 M6 Join Date: Dec 2017
02-23-2020, 12:21 PM | #297 | |
Drives: 2020 ZL1 Join Date: Dec 2019
02-23-2020, 05:01 PM | #298 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
So no reports of anything in 2018 or newer?
02-23-2020, 11:33 PM | #299 |
happens in 17s and 18s
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
02-24-2020, 06:24 AM | #300 |
Romans10:9-13
well, model year 18, but not actually build year in 18. That's what I am trying to confirm.
02-24-2020, 06:34 AM | #301 |
Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
the affected date range is listed in the thread somewhere in the first few pages
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
02-24-2020, 06:37 AM | #302 |
Romans10:9-13
Yep, just a thread almost 2 yrs old, just trying to see if there has been any updates to that 2017 build year spread and if there was actually a "change" that we know of.
02-24-2020, 07:54 AM | #303 |
Drives: 2018 ZLE Join Date: Feb 2018
Yes I believe that is correct. The model year 2018 cars that where built in 2017 seem to be the problems. I think there are even a few 2017 built in late 2016 that had a few failures too. I have not read or seen a car built in 2018 yet affected. Lets hope it stays like that.
02-24-2020, 08:07 AM | #304 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
I think they didn’t change the design of the pump, whatever the MY is.... May be the oil 5w30 to 0w40 Other than that, What is the difference between a 17 early 18 and a >19? |
02-24-2020, 08:14 AM | #305 |
Romans10:9-13
there is a mention that the pump part number DID change. Even a mention it went through 3 changes, but I did not read the other part numbers. Just saw 2 different ones.
02-24-2020, 09:44 AM | #306 |
02-24-2020, 10:23 AM | #307 |
Drives: 2018 ZL1 Black M6 PDR Join Date: May 2017
Stupid question. I have a 2018 ZL1, build date 8/17. What is the warranty on the oil pump? I only have around 3k miles but my 3 year will be coming up this fall.
02-24-2020, 10:42 AM | #308 |
