Old 11-27-2022, 03:54 PM   #1
SatinSteel
SatinSteel's Avatar
Drives: 2022 Camaro SS, F350 platinum
Speed engineering 1 7/8 long tube headers
Which length spark plug wires do I need. 10 inch or 12 inch. All stock
SatinSteel is offline   Reply With Quote
Old 11-27-2022, 05:10 PM   #2
Yang N’ Bang
17’ Hyper Blue 2SS
Yang N’ Bang's Avatar
Drives: 17’ Camaro 2SS
Your stock plug wires will be fine, just make sure there are no contact points, put sleeves on the plugs if you want be extra careful.
Yang N’ Bang is offline   Reply With Quote
Old 11-28-2022, 12:24 AM   #3
s346k
s346k's Avatar
Drives: like an old lady
all i can say about plug wires is that i tried 2 different sets of msd and removed both because they would back off the coil 1 click after running the car. ultimately bought granatelli wires.
i have 2" se headers, i tried the stock wires and there is no way they would've worked, even with sleeves. there were two cylinders, i want to say 3 & 5, that the boot physically would not go on on the plug. i forced one on #3 and demolished it with pliers trying to remove it.
Old 11-28-2022, 05:11 PM   #4
SatinSteel
SatinSteel's Avatar
I appreciate the input. But when I go to speed engineering's website they ask if u want to add spark plug wires but you can select 10 or 12 inch...
http://https://speed-engineering.com/collections/2016-2020-camaro-ss-1le-zl1-exhaust/products/lt1-lt4-camaro-1-7-8-longtube-headers-2016-6-2l-engine-m2
Old 11-28-2022, 06:03 PM   #5
s346k
s346k's Avatar
perhaps you need to measure the ones you have and make your own decision?
Old 11-28-2022, 08:44 PM   #6
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Hey SatinSteel,
I’ve Been going through the same question that you asked. In the end, I went with speed engineering 12 inch wires because I figured it was better to “have and not need” versus “need and not have”. Plus, a couple other awesome members on the site recommended the 12” wires if headers were going to be added. I looked all over for them and ended up finding some today at Michigan Motorsports. I also picked up some ARP stainless steel 12-point header bolts for my upcoming install.
Here’s the details if you need them…. Good luck with your build..
https://www.michiganmotorsports.com/...0-6-2-engines/
https://www.michiganmotorsports.com/...ainless-steel/
SHE'Z 18 is offline   Reply With Quote
Old 11-28-2022, 09:31 PM   #7
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
The 12" for any long or mid length headers. The extra length gives you a little more movement to turn away from the header tubes. I've run them on my 16ss, my 16 C7 and they are the best wires I've run. I don't have them on my Lt1 because I have stock manifolds.
Old 11-29-2022, 09:29 AM   #8
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
I used 12" with my headers along with plug wire boots, but 2" LT headers vs 1 7/8ths
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
Old 11-30-2022, 04:35 PM   #9
SatinSteel
SatinSteel's Avatar
Sounds good guys. 12" it is.
