09-02-2020, 02:18 PM | #1 |
SPL Toe Arms
The WHAT
SPL makes some of the best upgraded suspension I've ever seen. In this case, the rear toe arms on the SS 1LE are eccentric to adjust toe in and out. The SPL arms throws away the g0d d@mn movable suspension piece and TTY bolts (look it up) and replaces it with this *ta-da* The WHY The local Pep-boys did custom alignments for me, neat. They also didn't tighten the rear adjustment... so it was moving WHILE i was driving and shredding the lil tabs that hold the washer in the first place, not neat. Summary If you track your car, get these... otherwise pretend this thread never happened. *Pro tip... Vivid Racing is an SPL vendor, and offers % off from time to time
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
09-02-2020, 02:33 PM | #2 |
nice looks good ! ive been talking to the guys over there they seem like good people!
09-02-2020, 03:17 PM | #3 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
What made you go with SPL instead of BMR im in the market for suspension components but i noticed that SPL are alot more expensive then BMR.
09-02-2020, 03:26 PM | #4 | |
SPL = $368 @ vivid BMR = $269 For the $100 difference, get the better product.
09-02-2020, 04:02 PM | #5 | |
So, for us hillbilly non-1LE guys, is this a worthwhile upgrade on a mostly street & 1/4 mile car? Or really just a track item?
09-02-2020, 04:25 PM | #6 | |
I got a little different let me know if I have the wrong components. SPL Rear Toe Arms w/ Ecceentric Lockout Kit $386 BMR rod end $289 SPL Titanium Series Rear Lower Traction Arms $359 BMR lower Trailing arm $229 SPL Titanium Series Rear Upper Traction Arms $359 BMR Upper Trailing arm $229 SPL Titanium Series Rear Upper Control Arms $359 BMR upper control arm $229 SPL total $1463 BMR $976 Difference $487 Is it worth the deference? |
09-03-2020, 06:50 AM | #7 | |
Drives: Camaro 1ss Join Date: Nov 2019
So if saving every ounce possible and having the best of the best is worth it to you then SPL is worth the 500$ difference. IF not well save some money and buy BMR.. I personally LOVE SPL's stuff and at some point in time plan on using their full catalog.
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
09-03-2020, 08:38 AM | #8 | |
09-03-2020, 09:44 AM | #9 | |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
09-03-2020, 10:11 AM | #10 | |
Drives: '19 ZLE, S54 E36M3 Join Date: Feb 2018
BTW, the SPL parts are aluminum, not titanium, according to their website. Probably need to add a zero to the price tag for Ti... |
09-03-2020, 10:43 AM | #11 |
Thanks (Noted for next time)
09-03-2020, 04:22 PM | #12 |
So for anyone that is interested in the full lineup of SPL parts here are the links broken up from front and rear. You can probably get them cheaper at Vivid Racing or any other vendor but at least you know the part # required.
Rear Parts Rear Knuckle Bushings - https://www.splparts.com/products/re...en-camaro.html Rear Toe Arms - https://www.splparts.com/products/re...c-lockout.html Rear Lower Traction Links - https://www.splparts.com/products/re...maro-gen6.html Rear Upper Traction Links - https://www.splparts.com/products/re...maro-gen6.html Rear Upper Arm (Camber) - https://www.splparts.com/products/re...maro-gen6.html Front Parts - Front Lower Control Arms (Roll Center and Camber) - https://www.splparts.com/products/fr...maro-gen6.html Front Tension Rods (Castor) - https://www.splparts.com/products/fr...maro-gen6.html Bumpsteer adjustable tie rod ends (not available yet) - https://www.splparts.com/products/bu...ming-soon.html |
09-04-2020, 09:01 AM | #13 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
In addition to the advantages stated in the first post, this should also allow more range of adjustment for rear toe. That, in turn, should allow more rear negative camber without toe-in. If this mod were allowed in the class I compete in (autocross), it would probably the first mod I would do.
Matt Miller
2020 SS 1LE |
10-06-2020, 04:14 PM | #14 |
just ordered up some today from vivid racing also ! they had the best price
