08-25-2019, 05:40 PM | #43 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
The fronts fit, but it is within a gnats ass. No rubbing on the strut or on the fender liners up front. Back has plenty of room everywhere. 305-30-19 RE71R tires.
08-25-2019, 05:53 PM | #44 |
Drives: 2019 ZL1 Join Date: Aug 2018
Shouldn't be any issue, I've done 23 runs on a similar setup and the same tire. I did clearance the strut ears so the wheel rim didn't hit them at max negative camber setting at the hub. When I get the camber plates installed, I'll dial that back some so then I won't need as much of a spacer up front.
10-25-2022, 05:42 PM | #45 |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
Did you run flow formed or forged? Looking to pick up a set of apex for my ZL1 (non-LE) for track duty
10-29-2022, 09:19 PM | #46 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
I'm on 19"s
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
10-30-2022, 12:43 AM | #47 |
Not a Gen6
Not a Gen6 but Gen6 wheels and tires with 1” lowering springs.
Orange Krush II
