Old 03-24-2017, 09:50 AM   #1
BlownSSVert
BlownSSVert's Avatar
Drives: 2013 A6 1SS Vert Supercharged
Need Opinons
I just recently had my car supercharged by Rick @ J&R Performance. I just wanted to pick the brains of some of the more experienced forced induction guys on here. Rick had some excellent insight and knowledge but I always like getting multiple opinions. A full list of performance mods in in my sig. Thanks
Officer, what do you mean my car is too loud?
BlownSSVert is offline   Reply With Quote
Old 03-24-2017, 11:13 AM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
What were you looking for specifically? I didn't see a question anywhere? Are you just looking for "atta boys" from your mods? Not trying to be an a$$, comes naturally I guess, just trying to help you get what you are after.
Sounds like a supercharger and headers were bolted on to an otherwise stock engine. Should make for a fun daily driver. What kind of HP/TQ numbers did it put down?
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 03-24-2017, 12:49 PM   #3
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
Where is your after market CAI?
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 03-24-2017, 12:55 PM   #4
bayarea408
bayarea408's Avatar
Drives: T
my opinion is that this thread sucks with no pictures.
bayarea408 is online now   Reply With Quote
Old 03-24-2017, 01:32 PM   #5
Navy Chief MoonsSS
Navy Chief MoonsSS's Avatar
Drives: 2010 2SS LS3
Hey bud...welcome to the forum
Can you be more specific please of what you need opinions on?
LT headers (SW 1 7/8 with high flow cats),
Borla ATAK cat back exhaust
CAM (BTR stage 3 blower cam with all supporting mods Lifters, push rods, springs, head bolts, LS2 Timing chain, sprocket, Melling high performance oil pump, gaskets
SC (SLP TVS2300),
Black wing CAI (designed for SLP SC)
JRE super tensioner
Fuel system (ZL1pump/ADM control module/ID850 injectors)
wheels/tires
NGK TR7IX plugs
MSD wires
ZR1 3 bar map sensor
160° thermostat
Crank pin kit
Navy Chief MoonsSS is offline   Reply With Quote
Old 03-24-2017, 02:48 PM   #6
BigD6.6
Drives: 16 GMC Denali Dmax, 14 1LE, 10 SS
Welcome to the forum, sounds like your on your way to a nice build. Don't let the smartass's and trolls on here deter you from here as there is a lot of good stuff on here.
I had J&R Performance build my 1LE, they do great work, super clean and runs great with no issues in almost 3 years. I've had all my work including oil changes done with them. Those guys really know Camaros.
How do you like the extra power? What else are you planning to do in the future? Post up some pics when you get a chance.
Good luck with your Camaro.
BigD6.6 is offline   Reply With Quote
Old 03-25-2017, 03:56 AM   #7
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 03-25-2017, 02:03 PM   #8
BlownSSVert
my bad on the CAI, I forgot to include that in my sig. I have a Rotofab. To elaborate, what direction do you guys think would be best mod wise? I could go more power, or more handling. I want to make more power, but at the same time I don't want to overpower what the suspension and brakes can handle. that I guess is where my dilemma lies. pics soon
Old 03-25-2017, 02:38 PM   #9
BlownSSVert
pics
Old 03-25-2017, 05:49 PM   #10
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Are you manual or auto?, i dont see them listed on you sig, more fuel is always a plus, rear end expecially if you plan to drag with slicks, and then if your a manual a clutch oops forgot trailing arms and toe rods
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 03-27-2017, 02:05 PM   #11
BlownSSVert
It's an Auto. Drag is the direction I plan to go
Old 03-27-2017, 05:53 PM   #12
Moreair1
Moreair1's Avatar
Drag racing at the track you will probably run into an issue,verts can only run up to 13.5s before they will require a roll cage, but I would start on more suspension upgrades, then a stall convertor, then possibly gears, after that more fuel upgrades to get more power, since your an auto you have a better chance on your rear surviving buy maybe others can give you tips on that aspect
Old 03-27-2017, 06:57 PM   #13
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
What kind of power is it making now? I'm sure it's a real nice driving care. All I would do is get a set of light weight wheels, 18x12 in the rear and a good set of drag radials of your choice. Maybe a line lock and a better locker for the rear axel. You're set. You will have a car that is real fun to take down the 1/8th or 1/4 mile. If you want a little more, add a cam and a stall converter. You'll make a little more mid/top end power and the stall will get you a better 60' time.
UNRIVALED SS is offline   Reply With Quote
Old 03-28-2017, 08:41 PM   #14
Batmanntexas
For drag racing, you will definitely need to work on the rear suspension. These cars are known for serious wheel hop issues. Cradle bushings, toe rods, and trailing arms correct this. As others have mentioned, being an auto, you have a 3.27:1 rear end gear ratio, so a stall converter and line lock would serve you well. The light weight wheel recommendation is also sound advice, as well as some drag radials.
I'd probably look to upgrade both the rear-end and driveshaft if drag racing becomes a regular occurrence for you. The transmission is pretty reliable to about 650RWHP, if I recall correctly.
COTW 9/8/14
