03-14-2017, 03:51 PM | #1 |
Drives: Grey Camaro 2SS Join Date: Jul 2016
Questions about reaching 600+ rwhp
Hey guys, so I've been doing some research for the past few months and I want all your opinions and experiences with reaching my goal. I drive a 2010 Camaro 2ss manual. I want to reach at least 600 rwhp, my budget is about 20k-30k. My mods so far are a borla exhaust and a hotchkis stage 3 suspension kit. What other mods would be necessary to have it be a safe and reliable daily driver? Oh and I do plan on going with a supercharger for sure, probably a magnuson tvs2300.
03-14-2017, 04:04 PM | #2 |
Drives: All things Turbocharged Join Date: Dec 2010
You said it has to be supercharger but does it have to be a PD type blower? With a manual car and your budget, 600whp is a very brief stop on your way to way more. A big centri does big power much better.
03-14-2017, 04:13 PM | #3 | |
Drives: 2010 2SS LS3 Join Date: Jun 2016
http://www.camaro5.com/forums/showthread.php?t=458853
LT headers (SW 1 7/8 with high flow cats),
Borla ATAK cat back exhaust CAM (BTR stage 3 blower cam with all supporting mods Lifters, push rods, springs, head bolts, LS2 Timing chain, sprocket, Melling high performance oil pump, gaskets SC (SLP TVS2300), Black wing CAI (designed for SLP SC) JRE super tensioner Fuel system (ZL1pump/ADM control module/ID850 injectors) wheels/tires NGK TR7IX plugs MSD wires ZR1 3 bar map sensor 160° thermostat Crank pin kit |
03-14-2017, 07:00 PM | #4 | |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
I remember saying that. Easy to make that HP and a lot more on that budget depending on what route you want. If SC, then you're going to have to header up, mess with pulleys. Not sure what the Hotchis kits has but suspension mods like trailing arms, toe rods, beefier rear diff, axles and driveshaft, solid cradle bushings, clutch.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-14-2017, 11:41 PM | #5 |
I also had a procharger in mind, specifically the i-1 procharger. Any thoughts on that?
03-14-2017, 11:50 PM | #6 | |
03-14-2017, 11:58 PM | #7 |
Drives: CGM 2SS/RS Join Date: Jul 2012
Dreksnot completely right, mine also was supposed to my "daily" now I need a new daily.
The second you pass that 550 mark with a blower you enter a world of a ton of supporting mods, gambling on whether or not you were lucky to get a motor that lasts (pending good tune of course) and that power and above has the awesome abality of exposing all your weak links (i.e. clutch to axles). You gotta pay to play is understatement. |
03-15-2017, 12:05 AM | #8 | |
03-15-2017, 10:25 AM | #9 |
Turbo/Turbos would be an easy route to 600, easier than SC. They allow the car to be much closer, or just like it was before, the daily driver. That is, unless, you cam the car, which isn't necessary for that power level. Way back when my twins were installed, and with a poor tune, I was at 590, then a better tune at 632, then added a boost controller to hit 672, and so on... Stock everything else on the car so it was a daily driver with some power on reserve at the punch of the throttle. That being said, a centri is also a great route to go. A top mount SC will need "aid" to get to that desired power level and remove some to that daily cruise comfort. So many directions to travel to obtain that power, but all are great.
It looks like your Hotchis is more of a cornering-style upgrade and not straight-line. If you're only planning on running on the street with street tires, not much issue there. But ONCE you decide to take it to the strip to see what it will do (I did that once, also), then that's a whole different story for the suspension components - that's the part where you'll need stronger diff, axles, trailing arms, toe links, and the such.
03-15-2017, 10:59 AM | #10 |
Drives: 2011 Camaro 2SS Join Date: Sep 2015
My car was my daily when it had a F1X, and I still drive it pretty often now that it's on twins. Either one is pretty easy to daily if you don't mind the noise and mpg. 600 rwhp on a stick is cake. Either one should be easily obtained. LSA would to be honest the cheapest and most factory option in my opinion. Or you could drop a 416 or 427 in it if you want to hit 600rwhp n/a
03-15-2017, 11:19 AM | #11 |
BOHIC
Drives: 2010 Camaro SS "Enola" Join Date: Jun 2014
I have 633 on mine. Just check the signature and my garage.
What else can I do to my Camaro?
03-15-2017, 01:49 PM | #12 | |
I don't think the i-1 can support that much power so I would recommend the ECS kit. As it ships out of the box it is all the airflow, belt system, pulley etc. you need for 800whp. |
03-15-2017, 02:12 PM | #13 |
Last i seen the i-1 maxed out at 8 psi(I stand corrected they do have a upgrade to 9 psi now)plus it was also around 2/2500 dollors more than other superchargers, if you want flexible boost i would just go turbo, if not i would stay with your other options listed imo
Cai intake and a few other mods😎
03-15-2017, 03:11 PM | #14 | |
