Old 09-17-2020, 08:46 AM   #29
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
So, for my 2017 ZL1, owners manual says nothing about using full synthetic, only synthetic blend. Also mentions nothing about an LT4. HP supplement mentions nothing about oil type. My oil cap just says dexos. I used my dealer freebies at 500 and 1500 miles. They used dexos blend which was fine for me because I believe that's a better way to break in. Since then it's been nothing but Mobil 1. I know in 2019 they started recommending 0-40 ESP, but for you guys with 17s and 18s, is your manual saying anything different than mine? Oil cap just Dexos or Mobil 1?
I typically buy two 5 qt jugs from wallyworld and a PF64 off Amazon all for about $50 and my dealer would change it for $10-20 depending on kind of special they were running.
Zed, my 2017 ZL1 has Dexos on the cap and 5W30. On the top panel of the radiator support there is a sticker that has AC Delco/ Mobil 1 printed on it. I use Valvoline synthetic 5W30 in mine.
Old 09-17-2020, 09:00 AM   #30
Lafourche1
Drives: 2019 CLA 450 Mercedes
The 5/30W Dexos I oil is fine for daily use. The '19 and up shipped with the 0/40W ESP Dexos II oil because it is street and track certified. One less fluid change to deal with on track days. However, all years are fine with the 5/30W Dexos I oil for daily driving.
No matter what brand you put in, I would recommend a Dexos I or Dexos II certification in case of a warranty claim.
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red
2014 Lincoln MKT EcoBoost (The Bus)
Lafourche1 is offline   Reply With Quote
Old 09-17-2020, 01:44 PM   #31
HDRDTD
Take a look at your invoice. What type of oil does it say was used?
If it just says Dexos, then the dealer just filled it with the usual bulk Dexos oil they use on regular cars and not a full synthetic like Mobil 1 which is a lot less expensive although it does meet manufacturer spec for your car.
Also, quite often dealers will have a 'special' discounted price on their 'oil change with 27 point inspection' service.
Old 09-17-2020, 03:00 PM   #32
ember1205
Hot Camaro
ember1205's Avatar
Your statement here is not necessarily accurate. A significant percentage of dexos1 oil is available as 100% synthetic and not a "blend". I personally use the 5W-30 Kirkland oil from Costco as it's $25 for 10 quarts (Comes in a box of 2 5 quart jugs).
https://www.gmdexos.com/brands/dexos1/index.html
Old 09-17-2020, 03:20 PM   #33
supersportss
Drives: 2019 SS
I did my own with the miracle 0w-40 esp cost 105 with the filter. I now use 5-30 per the manual as I am not tracking my car, it's 25 now.
supersportss is offline   Reply With Quote
Old 09-17-2020, 03:43 PM   #34
HDRDTD
Of course you are correct in stating that not all Dexos is a blend, and I did not mean to imply that.
I was just pointing out that most dealers buy their Dexos in bulk as a generic 'Dexos' that is used in most oil changes unless the customer specifically asks for something else.
For example, when I get a oil change on my 2013 ZL1, I specify I want Mobil 1, and the oil change runs right around $89.95.
Whereas, an oil change on my 2015 Malibu 2,0T with the dealer recommended Dexos (Not Mobil 1) is only around $40 or so.
And no, I have no idea if the dealer recommended/supplied Dexos is a blend or not, but I suspect it's probably not considering the lower cost, but it does meet the neccessary Dexos requirements for the car.
Old 09-17-2020, 04:54 PM   #35
Osbornsm
Drives: 2018 SS 1LE
Exclamation
809-88865635 x 10 was used according to the sheet, that's Acdelco 5w30 full sun.
Looked up the pn on rockauto and it's $3.50 a quart.
Well sob
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 09-17-2020, 04:59 PM   #36
ember1205
Hot Camaro
ember1205's Avatar
Well sob
What actually matters is that it's 5W-30 dexos1 oil. Your warranty remains fully in tact with any 5W-30 dexos1 oil.
Old 09-17-2020, 07:13 PM   #37
Bob RS
Drives: 2019 Camaro RS 1LT
With discount coupons from the dealership which I use everytime because my salesperson is very great at sending me these coupons my cost for full synthetic Mobile One comes to $49 .
Bob RS is offline   Reply With Quote
Old 09-17-2020, 11:05 PM   #38
metros11
Drives: 2018 SS 1LE
Originally Posted by vtirocz View Post
That's a good deal either way. It's worth noting that yours is a 2018 and calls for 5W-30 which is considerably cheaper (roughly half the cost for me) compared to the 0W-40 ESP on 2019 and later models.
The 5W-30 Mobil1 can be bought in 5 gal jugs and is about ~$45 for 10qt. The 0W-40 ESP Mobil1 (which I've switched over to) is only available in 1qt bottles and overall for 10qt is about twice the price of the 5W-30.
The key benefit of running with the newer stuff, other than cold start lubrication improvements, is that it doesn't need to be switched out when going to the track, per the owner's manual.
Hold up a sec, GM is requiring 0w-40 ESP on all LT1 models 2019+ even for the street? That doesn't make sense.
metros11 is offline   Reply With Quote
Old 09-17-2020, 11:06 PM   #39
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
I buy the oil and filter (Mobil 1 for both) and the dealership charges me about $27 to change the oil and filter.
It's the only way I can be reasonably sure they use the products I want. Then check dipstick and under car when I get home to make sure it was done right.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 09-18-2020, 07:20 AM   #40
ember1205
Hot Camaro
ember1205's Avatar
There's a whole thread on this.
In a nutshell... 0W-40 dexos2 has always been required for track use. In 2019, GM "swapped" their recommendations from "5W-30 with 0W-40 for track use" to "0W-40 with 5W-30 being ok for street use only." GM may have decided that the 0W-40 dexos2 offers better protection all around, but it's more likely that people were tracking their cars and not paying attention to the need to change out the oil. In other words, the change more likely came from legal than engineering.
Nothing has changed in the motors, and using 5W-30 desos1 on the street is still acceptable to GM and will not void your warranty.
Old 09-18-2020, 11:39 AM   #41
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
Could be a sale on there’s a coupon on my dealership site 6 qt oil change $59 8 qt is $69 or $79
NYJets12 is offline   Reply With Quote
