09-03-2020, 10:24 AM | #1 |
Drives: 19 Z06 Join Date: Nov 2011
Are High flow valves worth it for catch can install?
Hey everyone, so I was wondering if high flow valves are worth it if you install a catch can on your car and do they provide much better flow.* To be clear this thread is not if you need a catch can, but if you decide to get one, are the high flow valves really worth it? I tested 3 valves, one of which was the Elite Engineering.* The results were surprising and I'll save you the trouble of you don't want to watch the video, but in a nutshell I think these high flow valves are worth it.* Also full disclaimer here folks, I'm not associated with Elite in any way and bought the valves with my own money, so there is no sponsorship.
https://youtu.be/wLV3gO-nUds
Gone but not forgotten:
1974 Corvette Stingray 454 1986 Z28 2009 Mustang GT convertible 2012 45th 2SS Vert 2013 ZL1 M6 2014 Zl1 M6 2014 GT500 2016 Challenger Hellcat M6 www.youtube.com/c/garageking Last edited by v8; 09-03-2020 at 10:26 AM. Reason: spelling |
09-03-2020, 09:11 PM | #2 |
Drives: 2018 Summit White 1LE Join Date: Oct 2019
Just curious, what is your application?
I just installed a Elite Engineering E2 Dual port on my LT1. EE said I do not need any check valves. Russ |
09-03-2020, 10:09 PM | #3 |
I'm installing them on my LT4 so because its a boosted engine they are needed. You are right on your LT1 they are not needed as you are vacuum only. I had an apex catch can on my LT4 and I will be putting the E2-X on and filming it. I'm also going to do a comparison to see how well the Elite works.
1974 Corvette Stingray 454 1986 Z28 2009 Mustang GT convertible 2012 45th 2SS Vert 2013 ZL1 M6 2014 Zl1 M6 2014 GT500 2016 Challenger Hellcat M6 www.youtube.com/c/garageking |
09-04-2020, 06:58 AM | #4 |
Drives: Turbo 6.2 Join Date: Feb 2019
If you are boosted and need a check valve that video sums it up nicely.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
09-04-2020, 08:50 AM | #5 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Great video I ordered Elite Engineering E2-X Ultra can with the high flow valves.
09-04-2020, 09:25 AM | #6 |
Thanks!!!!
09-04-2020, 09:29 AM | #7 |
That will be a great set up!!!!
09-04-2020, 01:37 PM | #8 |
Now I'm not sure if I should risk reusing the bolts like Elite said they have done alot of times. Or replace them snice i have read horror stories about breaking them.
09-04-2020, 11:56 PM | #9 |
09-05-2020, 07:05 AM | #10 |
Drives: 2023 SS 1LE Join Date: Mar 2020
09-05-2020, 07:11 AM | #11 |
Supercharger to head bolts there are alot of discussions about the bolts snapping because they are TTY. But Elite and other members have reused them with no problem. I think guys are just not using the correct torque.
09-05-2020, 07:59 AM | #12 |
Ahhh. Ok, that makes sense. They are 89 inch pounds torque to yield bolts, one time use only. That not much torque so I could see how they might snap if over torqued.
09-20-2020, 09:10 AM | #13 |
I reused mine when I installed my oil separator and have had no issues, but I'm stock, so maybe those that crank up the boost may have problems. I don't think those bolts are torque to yield.
Tags |
catch can, elite engineering, elite engineering catch can |
