07-10-2023, 06:11 PM | #1 |
Drives: 23 ZL1 1LE Join Date: Jul 2023
Best tire for the Zl1 1LE?
Hi,
I use my ZL1 1LE on track and street any suggestions I was looking at the stock tire again the Goodyear super car 3R or the Michelin 4s or even the Michelin cup 2. -2023 camaro Zl1 1le auto |
07-10-2023, 06:28 PM | #2 | |
Drives: 2020 SS 1LE Join Date: Jan 2023
Beat case scenario, get a second set of track wheels/tires and swap them out. I seen a few people use 3Rs in the wet and do okay. Others say its a death trap. |
07-10-2023, 08:21 PM | #3 |
Drives: Zl1 1le Join Date: Apr 2018
If by street you mean daily driver then get two sets of tires - the OEM and a set of street tires. If by street you mean occassional and mainly good weather just use OEMs.
07-11-2023, 09:56 AM | #4 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Need more info... Are you wanting to run only ONE tire for both applications? or two... I LOVED the factory tires, but I ran into traction problems after 700rwhp, so I bumped up to the TOYO R888R's 305/30 up front and 345/30 out back.... they hook MUCH better IMO, and when when warm, and on the right road, I can hook in second with around 770rwhp.
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
07-11-2023, 10:03 AM | #5 |
BanHamWatch
Drives: 21 ZL1 1LE Join Date: Jan 2021
Not to offend but those 345 look out of place on the car. Kinda large sidewall drag tire look not my thing. Anyway for the OP tyretest just compared the 6 rear old and still very good Michelin and new Conti Extreme Contcts. Maybe watch the video to help you decide. Can’t go wrong with either it looks like.
2021 ZL1 1LE
Auto |
07-11-2023, 11:03 AM | #6 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
If they make them in ZLE sizes I’d suggest the Goodyear Eagle Supercar 3, which come on the ZL1. Once warm they are pretty grippy. They’re also cheaper than the Michelins but have a little better warm grip. They are bad in cold weather, like all summer tires.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
07-11-2023, 11:04 AM | #7 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
The TOYOS are pretty grippy and are generally the tires of choice for roll racing. Their BIGGEST drawback is that they are horrendously NOISY. GY3's are a decent compromise if you want a track/street tire setup. They ARE NOT as good a street tire as MS4S but the definitely are faster than MS4S tires on the track. So basically I use 305 30 19 MS4S tires on 19 x 10.5 APEX SM-10 ET22 rims for daily driving and MICHELIN slicks size 30 65 18 for road racing on 18 x 11 EC-7 APEX ET25 wheels . I run both of these SQUARE set ups and I rotate.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 07-11-2023 at 11:17 AM. |
07-11-2023, 11:46 AM | #8 |
If you're looking for a tire that you can drive on the street and the track (road course) in dry and wet conditions above 40F, the Michelin 4S will be hard to beat. However, it's no good at the strip or below 40F.
'20 ZL1 1LE A10,
07-15-2023, 06:19 PM | #9 |
Drives: 2015 Z/28 Join Date: Jun 2011
Any rubbing with the 345s?
07-15-2023, 08:36 PM | #10 | |
No offense taken... but thats the first ive heard someone picking a tire based on how the sidewall looks? Not sure i follow... I just wanted to most amount of meat out back, and the 345 is what I found
07-15-2023, 10:48 PM | #11 |
Zero for me... I think the 345's have an issue on standard ZL1's though...
07-16-2023, 08:11 AM | #12 |
My 345 don't rub either
'20 ZL1 1LE A10,
07-16-2023, 10:00 AM | #13 | |
Drives: 2020 Camaro ZL1 Join Date: Jun 2022
07-17-2023, 06:11 AM | #14 | |
Drives: 1977 Pontiac Trans Am Join Date: Oct 2019
One note if you have not driving slicks before do not start with those. Slicks are great until they are not. Street tires will squeal at you when close to the limit slicks don't they just let go. if you are new to the hobby learn the car and the feel on street tires before going to slicks. |
