Old 08-02-2022, 09:44 PM   #1
Classic Muscle
Drives: 22 SS 1LE
Rear wheel lift entering driveway
I've heard people mentioning this before, but figured I'd post a video:3 Wheel Motion
Classic Muscle is offline   Reply With Quote
Old 08-02-2022, 10:08 PM   #2
JustinZL1
Drives: 2017 Focus RS
Cars with a stiff chassis will do that it’s not unusual
2023 ZL1, M6, Shadow Gray
JustinZL1 is offline   Reply With Quote
Old 08-03-2022, 12:11 AM   #3
Aragorn
Drives: Camaro SS 1LE
Yep. pulling into steep driveways sideways and I swear this happens.
Aragorn is offline   Reply With Quote
Old 08-03-2022, 01:22 AM   #4
s346k
s346k's Avatar
Drives: like an old lady
i live off a county road. when i turn left out of my driveway the car does this every time.
Old 08-03-2022, 06:13 AM   #5
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I had mine do that with the Phastek springs, they are stiff and not much travel so it will happen on certain inclines.
Old 08-03-2022, 06:36 AM   #6
vampire
vampire's Avatar
Drives: '19 M2C / '19 ZL1
i do a micro one-wheel burnout every time i park at home because of this ``
vampire is offline   Reply With Quote
Old 08-03-2022, 06:36 AM   #7
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I could do a steep driveway but only straight on, never at an angle. My 1LE splitter would clear on entry but something unseen would minorly scrape on exit.
Old 08-03-2022, 06:37 AM   #8
WhiteMale
Looking at your video just get more 90 degree to the entry and not at an angle, that's nothing.
Old 08-03-2022, 06:43 AM   #9
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
Happens all the time, nothing to see here. Perfectly normal.
Nothing like an SS is offline   Reply With Quote
Old 08-03-2022, 07:24 AM   #10
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Actually this is a good thing for us track rats because if you jack the car up in front of the rear wheel you can get BOTH wheels off the ground on that side of the car. If you run 18 inch wheels depending on your overall tire diameter , sometines there is NOT enough room just behind the front wheel to get a jack underneath the car My 315 30 18 tire setup for the track for instance is TOO LOW to the ground in FRONT to get a jack underneath
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 08-03-2022, 09:09 AM   #11
Classic Muscle
Drives: 22 SS 1LE
Yeah, if I ride the clutch and try to ease it up the hump in the driveway, the traction control tries to manage the wheel slippage and the the diff. noise is a little disconcerting from inside the car... can be heard in the second part of the video. First couple times I heard it I thought I was scraping the splitter, so I had my daughter make the video it to see what was happening. If I don't push the clutch pedal in, and just maintain some momentum in 1st and give it a little gas, it doesn't make the noise.
Old 08-03-2022, 09:13 AM   #12
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
That is normal...the chassis has little to no flex which is a good thing.
2016 NFG 1SS A8
Options-2SS Leather/NPP
