07-15-2014, 09:41 PM | #15 |
Drives: 2013 SS Join Date: May 2013
Iorn block FTW!
Throw everything at it and it just laughs
07-16-2014, 11:01 AM | #16 | |
07-16-2014, 12:36 PM | #17 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Hit the "search this forum" button in the upper right hands side of the screen and type in stroker build. Should give you quite a bit of reading.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
07-16-2014, 04:26 PM | #18 |
07-16-2014, 04:50 PM | #19 |
Drives: 1989 GTA Trans Am Join Date: Jun 2012
I would say crankshaft, piston and rings for sure. I think you can reuse your rods if you wanted or go forged for the extra safety. Milage, probably down a couple on the highway. Can't help on the power gain.
07-16-2014, 06:17 PM | #20 |
Geek
Right. You can buy full kits from TSP if that simplifies it for you. I would do the rods while you're in there. Your gain from stroking to 416ish is going to be torque. Add cubes for TQ. It adds some HP, but you probably wouldn't be impressed. You could bump your CR up with heads at the same time and maybe end up around 550/550. That's a great place to start adding nitrous with your new, forged rotating assembly.
The parts aren't all that expensive, somewhere between 2 and 3k for the rotating assembly. You will have to pay a machine shop to put the shortblock together for you though. You'll also want a new cam. You might also be looking at dealing with a fuel system. I know my stock pump is dropping PSI with just bolt-ons and a cam.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
07-17-2014, 09:14 AM | #21 | ||
Thanks for the help guys. What's the full name for TSP? I was wanting to do a cam already, and figured it might save some money if I did this at the same time. |
07-17-2014, 09:27 AM | #22 |
Geek
Texas Speed and Performance
https://www.texas-speed.com/c-503-ro...ssemblies.aspx You will need a bigger cam with those extra cubes. I would recommend Brian Tooley Racing to spec you a cam. He can probably get you the rotating assembly too. Give him a call and he can set you straight.
07-17-2014, 01:50 PM | #23 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Stroker kit, to stroke your stock engine to 417 CID, would typically include crankshaft, rods, pistons, rings and bearings. Then the rotating assembly might need to be balanced, and then everything assembled.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
07-17-2014, 09:50 PM | #24 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
You can safely turn your LS3 into a 427-454 with a sleeved block from ERL. Without sleeving I would stick to the 4" crank stroke for 416-418ci.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
07-17-2014, 11:16 PM | #25 |
Geek
And if you're going with ERL... why not just go superdeck 502.
07-17-2014, 11:19 PM | #26 |
Geek
Weird. Didn't they used to offer a Superdeck II? I could swear I was drooling over their 500+ blocks at one point.
